nguil
SCCM 2012 sp1 setup issue with sql 2008 R2
Hi all,
I have an error with the required version of sql server when I install SCCM 2012 SP1.
see attach files.
But the version of the sql server is 2008 R2 64bits SP1 CU 6.
The account which I use to install sccm 2012 is local administrator of sccm server and sql server.
And this account is sysadmin in sql.
Here is the ConfigMgrSetup.log :
CWmiRegistry::GetStr: Failed to get string value MSSQLSERVER $$<Configuration Manager Setup><03-21-2013 22:31:20.007-60><thread=2192 (0x890)>
Failed to retrieve SQL Server instance name[MSSQLSERVER]. $$<Configuration Manager Setup><03-21-2013 22:31:20.060-60><thread=2192 (0x890)>
WARNING: failed to retrieve port number for 20ssql.xxxxx.com . $$<Configuration Manager Setup><03-21-2013 22:31:20.060-60><thread=2192 (0x890)>
INFO: Registered type 20SSQL.XXXXX.COM MASTER for 20SSQL.XXXXX.COM master $$<Configuration Manager Setup><03-21-2013 22:31:20.060-60><thread=2192 (0x890)>
INFO: Registered type SMS Master for 20SSQL.XXXXX.COM master $$<Configuration Manager Setup><03-21-2013 22:31:20.060-60><thread=2192 (0x890)>
INFO: Registered type 20SSQL.XXXXX.COM SCCM for 20SSQL.XXXXX.COM SCCM $$<Configuration Manager Setup><03-21-2013 22:31:20.060-60><thread=2192 (0x890)>
INFO: Registered type SMS ACCESS for 20SSQL.XXXXX.COM SCCM $$<Configuration Manager Setup><03-21-2013 22:31:20.060-60><thread=2192 (0x890)>
*** [08001][14][Microsoft][ODBC SQL Server Driver][DBNETLIB]Invalid connection. $$<Configuration Manager Setup><03-21-2013 22:32:29.153-60><thread=2192 (0x890)>
*** [01000][14][Microsoft][ODBC SQL Server Driver][DBNETLIB]ConnectionOpen (Invalid Instance()). $$<Configuration Manager Setup><03-21-2013 22:32:29.153-60><thread=2192 (0x890)>
*** Failed to connect to the SQL Server, connection type: 20SSQL.XXXXX.COM MASTER. $$<Configuration Manager Setup><03-21-2013 22:32:29.153-60><thread=2192 (0x890)>
*** [08001][14][Microsoft][ODBC SQL Server Driver][DBNETLIB]Invalid connection. $$<Configuration Manager Setup><03-21-2013 22:33:39.185-60><thread=2192 (0x890)>
*** [01000][14][Microsoft][ODBC SQL Server Driver][DBNETLIB]ConnectionOpen (Invalid Instance()). $$<Configuration Manager Setup><03-21-2013 22:33:39.185-60><thread=2192 (0x890)>
*** Failed to connect to the SQL Server, connection type: 20SSQL.XXXXX.COM MASTER. $$<Configuration Manager Setup><03-21-2013 22:33:39.185-60><thread=2192 (0x890)>
sccm server : win 2008 R2 std SP1
sql server : win 2008 R2 std SP1
I tryed to install on sql 2008 R2 SP2 with the same result.
I installed the management studio on the sccm server and I connect to the remote sql with no problem.
Have you an idea where is the trouble ?
Thanks,
I've put the SQL server name (FQDN) : 20ssql.domain.com, and I didn't put Instance name because I've used the default instance.
I enter a name for the database, and I keep the port 4022 for Service Broker Port.
Is it correct ?
