alittlelouder
Out-of-Band Management and Wake-on-LAN
Hey
Me again...
I've installed the Out-of-Band Management on my SCCM-Server and enabled Wake-on-Lan on the System Site (Doesn't matter if i enable unicast or subnet-broadcast).
If I check the option Wake-on-Lan in an advertisement of a Windows Deployment Task-Sequence the client does not start at the given time. The client stays powered off.
The problem is not the switch, neither the client. I've tested wake-on-lan with a freeware tool called "Wake On LAN Ex". If i try to wake up my client with this tool it works.
Could anyone help me?
Thank you very much.
alittlelouder
PS:
I'm having my final thesis of my apprenticeship in 2 weeks, SCCM is a part of it. That's why i ask such a lot questions... =D
EDIT:
Environment:
SCCM-Server - Win2k8 Ent. x64
SQL-Server - Win2k8 Ent. x64, SQL2k8 Ent.
Client - Win Vista SP1 Business x86
6 answers to this question
Firstly which version of SCCM are you using? Rightclick on your site and click properties. The information is below the general tab
If you look into resource explorer for the object you want to "wol"
Is the IP Address/Mac adress spesified here correct?
SCCM uses hardware information when sending out the wol packages.
what does these logs say?
<SCCM instal dir>\logs\wolcmgr.log
<SCCM instal dir>\logs\wolmgr.log
Hey wmmayms
  Quote
System Center Configuration Manager 2007 (SP1)
Version: 4.00.6221.1000
  Quote
Yes, the MAC-Address is available and correct
  Quote
They seem to be fine, i checked them with SMS Trace...
Hmm... very strange... It seems to work now... I didn't change anything... :huh:
Emm... Is it possible to make my client start in PXE automatically, I mean without changing any BIOS-Settings...?
Thank you
alittlelouder
Hey
I have to correct my self. I've tested wol on one client and it worked.
Now I've tried the WOL on a second client on wich it didnt work.
--> MAC-Address is available
Here are the logs for the second job.
wolcmgr.log
  Quote
Persisting job data for job id='4cbf18'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:13:23 2576 (0x0A10)
WOLCManager executing job id='4cbf18' in state 'STATE_PROCESSDATA'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:13:23 2576 (0x0A10)
WOLCManager processing data for job id='4cbf18'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:13:23 2576 (0x0A10)
STATMSG: ID=6504 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_WAKEONLAN_COMMUNICATION_MANAGER" SYS=WIDDPLSCC01 SITE=DPL PID=2004 TID=2576 GMTDATE=Tue Apr 14 09:13:23.380 2009 ISTR0="DPL20003" ISTR1="3" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=3 AID0=422 AVAL0="4cbf18" AID1=421 AVAL1="3" AID2=415 AVAL2="DPL20003" SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:13:23 2576 (0x0A10)
WOLCManager retry for job id='4cbf18' - 1 retries of 3 maximum completed). SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:13:23 2576 (0x0A10)
WOLCManager job id='4cbf18' will execute next in at least 60 seconds. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:13:23 2576 (0x0A10)
WOLCManager waiting 60 seconds for work. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:13:23 2576 (0x0A10)
WOLCManager waking up to process new jobs. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:13:23 2576 (0x0A10)
WOLCManager one or more existing jobs is ready. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:14:23 2576 (0x0A10)
WOLCManager executing job id='4cbf18' in state 'STATE_PROCESSDATA'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:14:23 2576 (0x0A10)
WOLCManager processing data for job id='4cbf18'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:14:23 2576 (0x0A10)
WOLCManager job id='4cbf18' will execute next in at least 1 seconds. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:14:23 2576 (0x0A10)
WOLCManager waiting 1 seconds for work. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:14:23 2576 (0x0A10)
WOLCManager one or more existing jobs is ready. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:14:24 2576 (0x0A10)
WOLCManager executing job id='4cbf18' in state 'STATE_PROCESSDATA'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:14:24 2576 (0x0A10)
WOLCManager processing data for job id='4cbf18'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:14:24 2576 (0x0A10)
WOLCManager retry for job id='4cbf18' - 2 retries of 3 maximum completed). SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:14:24 2576 (0x0A10)
Persisting job data for job id='4cbf18'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:14:24 2576 (0x0A10)
WOLCManager job id='4cbf18' will execute next in at least 60 seconds. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:14:24 2576 (0x0A10)
WOLCManager waiting 60 seconds for work. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:14:24 2576 (0x0A10)
WOLCManager one or more existing jobs is ready. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:24 2576 (0x0A10)
WOLCManager executing job id='4cbf18' in state 'STATE_PROCESSDATA'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:24 2576 (0x0A10)
WOLCManager processing data for job id='4cbf18'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:24 2576 (0x0A10)
WOLCManager job id='4cbf18' will execute next in at least 1 seconds. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:24 2576 (0x0A10)
WOLCManager waiting 1 seconds for work. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:24 2576 (0x0A10)
WOLCManager one or more existing jobs is ready. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:25 2576 (0x0A10)
WOLCManager executing job id='4cbf18' in state 'STATE_PROCESSDATA'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:25 2576 (0x0A10)
WOLCManager processing data for job id='4cbf18'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:25 2576 (0x0A10)
WOLCManager retry for job id='4cbf18' has completed (3 retries). SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:25 2576 (0x0A10)
STATMSG: ID=6505 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_WAKEONLAN_COMMUNICATION_MANAGER" SYS=WIDDPLSCC01 SITE=DPL PID=2004 TID=2576 GMTDATE=Tue Apr 14 09:15:25.375 2009 ISTR0="DPL20003" ISTR1="3" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=3 AID0=422 AVAL0="4cbf18" AID1=421 AVAL1="3" AID2=415 AVAL2="DPL20003" SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:25 2576 (0x0A10)
Persisting job data for job id='4cbf18'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:25 2576 (0x0A10)
WOLCManager waiting 5 seconds for work. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:25 2576 (0x0A10)
WOLCManager one or more existing jobs is ready. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:30 2576 (0x0A10)
WOLCManager executing job id='4cbf18' in state 'STATE_COMPLETE'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:30 2576 (0x0A10)
WOLCManager completing job id='4cbf18'. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:30 2576 (0x0A10)
WOLCManager waiting 3600 seconds for work. SMS_WAKEONLAN_COMMUNICATION_MANAGER 14.04.2009 11:15:30 2576 (0x0A10)
wolmgr.log
  Quote
WOLManager one or more schedules are due. SMS_WAKEONLAN_MANAGER 14.04.2009 11:13:23 2580 (0x0A14)
0 WOL client network data processed. SMS_WAKEONLAN_MANAGER 14.04.2009 11:13:23 2580 (0x0A14)
STATMSG: ID=6510 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_WAKEONLAN_MANAGER" SYS=WIDDPLSCC01 SITE=DPL PID=2004 TID=2580 GMTDATE=Tue Apr 14 09:13:23.239 2009 ISTR0="DPL20003" ISTR1="3" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=2 AID0=421 AVAL0="3" AID1=415 AVAL1="DPL20003" SMS_WAKEONLAN_MANAGER 14.04.2009 11:13:23 2580 (0x0A14)
WOLManager waiting 3600 seconds for work. SMS_WAKEONLAN_MANAGER 14.04.2009 11:13:23 2580 (0x0A14)
WOLManager waking up to process new jobs. SMS_WAKEONLAN_MANAGER 14.04.2009 11:13:38 2580 (0x0A14)
STATMSG: ID=6510 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_WAKEONLAN_MANAGER" SYS=WIDDPLSCC01 SITE=DPL PID=2004 TID=2580 GMTDATE=Tue Apr 14 09:13:38.192 2009 ISTR0="DPL20003" ISTR1="3" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=2 AID0=421 AVAL0="3" AID1=415 AVAL1="DPL20003" SMS_WAKEONLAN_MANAGER 14.04.2009 11:13:38 2580 (0x0A14)
WOLManager waiting 3600 seconds for work. SMS_WAKEONLAN_MANAGER 14.04.2009 11:13:38 2580 (0x0A14)
Thank you!
alittlelouder
  Quote
make sure that the pc's you are trying to WOL have had a clean shutdown first, a clean shutdown is where you tell the OS to power down using the start menu, a dirty shutdown is done by holding the power switch until all power is cut.
PC's in a dirty power down state, can fail to WOL, so be sure to check that....
