Rookie
Problem Recovering Exch2010 Server!!!
Hello everyone, I am trying to recover my failed server and I got this error after trying to recover. Anyone familiar with this?
Welcome to Microsoft Exchange Server 2010 Unattended Setup
Preparing Exchange Setup
Copying Setup Files ......................... COMPLETED
The following server roles will be recovered
Languages
Hub Transport Role
Client Access Role
Mailbox Role
Management Tools
Performing Microsoft Exchange Server Prerequisite Check
Language Pack Checks ......................... COMPLETED
Configuring Microsoft Exchange Server
Preparing Setup ......................... COMPLETED
Stopping Services ......................... COMPLETED
Copying Exchange Files ......................... COMPLETED
Language Files ......................... COMPLETED
Restoring Services ......................... COMPLETED
Languages ......................... COMPLETED
Hub Transport Server Role ......................... FAILED
The following error was generated when "$error.Clear(); Install-ExchangeCer
tificate -DomainController $RoleDomainController -Services SMTP" was run: "The i
nternal transport certificate for the local server was damaged or missing in Act
ive Directory. The problem has been fixed. However, if you have existing Edge Su
bscriptions, you must subscribe all Edge Transport servers again by using the Ne
w-EdgeSubscription cmdlet in the Shell.".
The Exchange Server setup operation did not complete. Visit http://support.micro
soft.com and enter the Error ID to find more information.
Exchange Server setup encountered an error.
I suppose (and hope) you solved this issue?
If not, I want you to investigate the installation log, which is placed by default on the C:\ExchangeSetupLogs
You can post it here if you want me and others being able to help you
Cheers
