OliAdams
build and capture sequences hang at Setup is starting services
I have now built 3 separate build and capture task sequences. All of the install the image restart to install the applications and hang at setup is starting services. One is using windows 7 ent standard wim. One is using Windows 8 standard wim and the last one was windows 7 pro. I do not know what I am doing wrong. Is there something extra I must do in SCCM 2012 SP1?
