Asher
SCCM 2007 OSD Distribution Point sync.
We are trying to update a new DP from our old DP where all our packages for winpe boot, image, and all the packages are existed that are deployed by the task sequence within. I know I can do this DP update on each package however, I would like to know if there are ways to do a one shot DP update for OSD and all its packages from OLD DP to New DP.
Thanks.
I just found one way we could do that is by copy package, then you will get pointed to distination DP you choose your DP then you will choose what packages you would like to send to the new DP. and press ok. Give it time as all the package contents are getting synched with the new DP.
Regards,
Asher
