xc3ss1v3 Posted May 29, 2013 Report post Posted May 29, 2013 what is the OS of the clients ?? Windows 7 Enterprise either 64-bit or 32-bit on all (in this particular case, 32-bit.). Quote Share this post Link to post Share on other sites More sharing options...
Atomic12 Posted October 20, 2014 Report post Posted October 20, 2014 Was this issue resolved? I am having the same problems but no solution... Quote Share this post Link to post Share on other sites More sharing options...
Iroqouiz Posted October 24, 2014 Report post Posted October 24, 2014 Was this issue resolved? I am having the same problems but no solution... The 0x80070643 error code means "fatal error during installation". How are you deploying the client? Client push? Quote Share this post Link to post Share on other sites More sharing options...
Atomic12 Posted October 27, 2014 Report post Posted October 27, 2014 Hi, it was due to the problem with DCHP option from VMware workstation, where I got for the first part of deployment an IP address from VMware workstation DHCP, and then after restart I got DHCP address from my DC which is correct. That is why my client didn't want to install. Thanks anyway Quote Share this post Link to post Share on other sites More sharing options...
Ajaz Posted April 29, 2015 Report post Posted April 29, 2015 Hi Guys, I was having the same issue as below from CCMSetup.log -----*****----- Installing file 'C:\WINDOWS\ccmsetup\vcredist_x86.exe' with options '/q /norestart /c:"msiexec /i vc_red.msi /qn REBOOT=ReallySuppress" /msioptions "REBOOT=ReallySuppress"'. File 'C:\WINDOWS\ccmsetup\vcredist_x86.exe' returned failure exit code 1603. Fail the installation. InstallFromManifest failed 0x80070643 Params to send FSP message '5.0.7958.1000 Deployment Error 0x80070643. Pre-req: vcredist_x86.exe' State message with TopicType 800 and TopicId {915EE94C-6625-42F7-99BE-DA6D39550C23} has been sent to the FSP Deleted file C:\WINDOWS\ccmsetup\ccmsetup.xml CcmSetup failed with error code 0x80070643 -----*****----- Solution: 1. Used following script to fix WMI. @echo off winmgmt /resetrepository sc config winmgmt start= disabled net stop winmgmt /y %systemdrive% cd %windir%\system32\wbem For /f %%s in ('dir /b *.dll') do regsvr32 /s %%s wmiprvse /regserver winmgmt /regserver net start winmgmt for /f %%s in ('dir /b *.mof *.mfl') do mofcomp %%s exit 2. Also used CCMClean.exe to clean any left overs or un-necessary links and files. 3. Installed SCCM Client again and it installed smoothly. Thanks 1 Quote Share this post Link to post Share on other sites More sharing options...
