denisrsd17 Posted June 3, 2013 Report post Posted June 3, 2013 Im having a hard time getting a Intel 82579LM Nic card to successfully install for deployment only using my WDS server. I have the capture setup fine, and using those same drivers, I cannot get the computer to communicate and successfully receive an image. Does anyone have the driver that works with this? I feel like Ive tried 200 of them and none of them will let it boot. Device ID is 1502. Thanks in advance, Denis Quote Share this post Link to post Share on other sites More sharing options...
0 denisrsd17 Posted June 3, 2013 Report post Posted June 3, 2013 To respond to myself a little here, when it fail boots on to the deployment server, I can manually load a driver and get an IP address, but that same driver when its the only one DISM'd in, does not work. Quote Share this post Link to post Share on other sites More sharing options...
0 btdag Posted June 4, 2013 Report post Posted June 4, 2013 Just to confirm a few things: Are you using a Windows 7 or Windows 8 Boot Image? Are you using Server 2008 R2? What driver is it exactly? e1c62x64.inf? Quote Share this post Link to post Share on other sites More sharing options...
Device ID is 1502.
Thanks in advance,
Denis
