krisjturn Posted June 4, 2013 Report post Posted June 4, 2013 Our current OSD TS is pretty basic at this time. Disabled Bitlocker, formats and partitions, deploys OS, configures OS, install apps, joins domain, etc. I am looking to start building on this base and include USMT processes as well. Does anyone have any good TS examples with advanced task that include rebuild or refreshes? Thanks! Quote Share this post Link to post Share on other sites More sharing options...
Iroqouiz Posted June 13, 2013 Report post Posted June 13, 2013 Check out MDT 2012 Update 1. If you integrate that with SCCM you get a bunch of advanced customizations to choose from, like a User Driven Installation with replace/refresh scenarios. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted June 13, 2013 Report post Posted June 13, 2013 here's a pretty advanced OSD task sequence, video included CM12 in a Lab - The CM12 BitLocker FrontEnd HTA CM12 in a Lab -The CM12 BitLocker FrontEnd HTA - video Quote Share this post Link to post Share on other sites More sharing options...
krisjturn Posted June 14, 2013 Report post Posted June 14, 2013 I will check it out. I haven't had much time with MDT. Everything I have ever done has been via OSD only and that has been limited. Most of my engagements usuallly have a large enough team and is seperated by role. However, I will be dealing with smaller companies and government agencies now and will be needed to ramp up my skills in this area a little more. Quote Share this post Link to post Share on other sites More sharing options...
