Rapp
Clients selecting the wrong MP
Hello
I have currently setup the following test environment
PRISCCM01.child.eellab.local - SCCM 2007 Primary Site
SECSCCM01.child.eellab.local - SCCM 2007 Secondary Site
CASSCCM01.eellab.local - SCCM 2012 Central Administration Site
PRISCCM01.eellab.local - SCCM 2012 Primary Site
I have deployments working in the SCCM 2007 environment without any problems and have now created the SCCM 2012 servers and started to test deployments.
However I have now come across a problem where when installing the SCCM 2012 client via OSD the client fails to talk with PRISCCM01.eellab.local.
Looking at the ccmsetup.log I can see that the machine is finding both the PRISCCM01 site on both the 2007 & 2012 sites then refusing to work as it wants to use the 2007 site which is an older version than the installed client.
What can I do to resolve this? Will I have to create a new site which hasn't reused the PRI site code and PRISCCM01 name? Is there issues using site names & codes again in the parent domain?
Is there a way to unpublish the SCCM 2007 names from AD?
ccmsetup.logFetching info...
client.msi.logFetching info...
