BzowK
Issue Installing Secondary Site
Good Afternoon All / Niall -
I'm working for a new company and helping integrate SCCM 2012 (SP1 / CU1) into the environment. It was started a couple of weeks before I came and hasn't worked correctly since arriving so we are trying to get it at 100%. The site runs a CAS server, Primary, and will eventually have ~50 secondary sites. The CAS is 08R2, Primary is 2012, SQL is 2012, and secondaries are 2012.
When deploying the secondary site role about a week ago, one of the guys had an issue where it failed. I worked on it this morning and can't get it to work. Below's the low down...
Secondary Site Re-Install Process (It failed installation first push & hasn't worked ever)
  1. Removed all roles from site server (dedicated SCCM Secondary)
  2. Uninstalled all SQL components
  3. Deleted it as site in Primary
  4. Checked pre-reqs - Local admins - Primary site hostname, service account / Roles & Features - BITS, IIS (+ all features), Remote Diff Compression, .NET 3.5, .NET 4, WCF Activation
  5. Restarted server
  6. Deployed Secondary site to server from console on Primary. Chose to have it install pre-reqs needed, to copy over files it needed, and to install SQL on it's own
After about 10 minutes, it fails. Here's the installation status after failing:
On the server, itself, I looked at C: for the logs. Most of the logs there seem to be from the previous attempt as only smstsvc.log was updated on my attempt:
(Deployed install at about 4:05pm 6/25/13)
In it, the only real error I can find is about AD (below). Other than that, it's fairly clear. I did check the System Management container and the hostname of the server has full rights delegated to it, though. Here's the last of the log file -including the error discussed above - so you can see how far it got. SQL components weren't even installed this time...
Any ideas? Thanks!
