NaasMarais
Custom WIM Deployment to Client Machine with Configmgr 2012 SP1
Hi All
I am new to the site and have run into a issue i cannot get resolved.
We have a ConfigMgr 2012 sp1 server running on Server 2008 R2 OS. Everything works fine just having issue gettting my Corporate Custom WIM to be perfectly applied to a machine.
My task sequence is as follows from the screen shot link, since I only want to apply the WIM I change the "Apply Operating System" with the "Apply Data Image".
https://docs.google.com/file/d/0B6lfGplH6zJEdHRBdExhWV9rTnM/edit?usp=sharing
The WIM applies but it fails on the "Setup Windows and ConfigMgr" settings, I have went through the smsts.log file and can see it says failed on the Install Updates but hell still cannot figure this out.
smsts.log https://docs.google.com/file/d/0B6lfGplH6zJEZk1wQUhURjZkMm8/edit?usp=sharing
The Custom WIM has Office 2013, Adobe x, 7zip and other apps already installed. The Image was sysprep with a unattend.xml file which enables admin, unattend join to domain etc
Can someone please point me in the right direction with this i am starting to pull my hair out. What is the correct way to apply a custom WIM with Configmgr 2012 sp1?
