Dritan Myftiu
problem deploying Win 2008
10 answers to this question
is the dhcp server on the same box or another machine ?
have you created both the X86 and X64 BOOT images and created Distribution points for them and updated the DP's ?
I read that topic. Not sure what they mean by:
Yes you need to configure
1. #60
2. #67 -- \boot\x86\pxeboot.com
3. #66 -- FQDN for SCCM server.
Mean time, on my AD both two groups were not created. I created them refer to your instructions.
Dritani
Hi Niall,
After did what you mantion earlier i am getting an diferent error:
Client mac address: _:......
Client IP 10.200.9.8 (from DHCP server ) mask 255.255.0.0 DHCP server 10.200.1.12 (true) gateway IP address 10.200.1.1 (true
TFTP
PXE-T04: access violation
PXE-E36 Error received from TFTP server
PXE-MOF Exiting Intel Boot Agent.
Dritani
you are nearly there !!!
access violation simply means that you need to do a Computer Association,
to see how that is done, scroll down to the section of this post which reads
  Quote
Add server to collection
Under Operating System Deployment, right click on Computer Association and choose import computer information,
once you've imported the server to the deploy collection the Access Violation error will disappear
niall
Hi Niall
Just followed the instructions on the link but the same errors:
TFTP...
PXE -T04: Access Violation
PXE -E36 Error received from TFTP server
PXE-MOF Exiting Intel Boot agent
I will try a bit later tonight and see.
Dritani
Hi Niall,
I restarted both and still the same.
Just let you know that AD is runnin on other server and the sccm server is runnin only sccm2007 nothing else.
If you need any details please let me know
Dritani
This is to much to ask, (and please acept my appology for that) if you want to have a look at the server I can make this available to you.
I am just desperate to finish this.
  On 5/6/2009 at 11:30 AM, Dritan Myftiu said:
Hi Niall,
Dritani
This looks alot like my post about the exact same thing!
2 years after the last reply in this post... :P
http://www.windows-noob.com/forums/index.php?/topic/3146-pxe-boot-requirements/page__st__20
Still looking for a fix..
