nevermind86 Posted July 10, 2013 Report post Posted July 10, 2013 hi all have recently setup my site server all is working well, have updated to sp2 to deploy windows 7 via PXE/OSD, having followed the guide here to accomplish this (which is great by the way) I have run into a problem that i have googled the crap out of and cannot resolve, have gone through my OS capture process with the boot image and task sequence and have gotten my .wim image fine, now I have pushed both boot images out to both DP's. I have tried configing WDS and not configuring it as there are mixed reviews on this. my ccm pxe role is installed succesfully confirmed with the logs. my operating system image is distrubted to the main sms dp not the pxe one. my task sequence is set to run as a boot image. it all appears correct. however when booting a client either virtual or physical the damn thing just stops on the below error, some people have suggested maybe enabling port 19/20 on my dhcp but im not convinced. please can anyone point me in the rite f***** direction, thanks. boot images dhcp scopeos installthepxe boot sms[xe log fileand finally task sequencesorry for the spam wasnt sure how best to present it, any help would be mucho appreciated !! Quote Share this post Link to post Share on other sites More sharing options...
nevermind86 Posted July 11, 2013 Report post Posted July 11, 2013 an update, changed the DHCP options from the FQDN of the server to its ip address, it now starts to PXE however the i get the error code "a recent software or hardware change has occured which is preventing the OS from startup up" \boot\bcd 0xc00000f !! Quote Share this post Link to post Share on other sites More sharing options...
Balthier Posted July 11, 2013 Report post Posted July 11, 2013 I'm having PXE problems myself. Sometimes it works, sometimes it doesn't. You could try this and see if it helps http://blogs.technet.com/b/configurationmgr/archive/2011/01/05/troubleshooting-the-pxe-service-point-and-wds-in-configuration-manager-2007.aspx You can also have a look here http://netsaber.wordpress.com/2008/07/15/configmgr-os-deployment-wds-and-dhcp-on-same-server-issueresolution/ Btw, when you have installed WDS, DHCP and PXE on the same server, what configuration changes do you make? Why have you set the two DHCP server options 66 and 67 manually? Quote Share this post Link to post Share on other sites More sharing options...
nevermind86 Posted July 11, 2013 Report post Posted July 11, 2013 hi, ill check them out now, i installed wds only and did not set it up, i let sccm do that, i have set 66 to point to the sms ip and 67 to point to the boot image (unc path) of the OS, another update:after unininstalling all pxe point and wds and resintalling step by step from a guide after the pxe has started it almost looks like the sequence is about to begin, hang for a few seconds like its trying to process something and i get lots of these "GetUnknownMachineResource (001,x86):" in my smspxe log.... anyone? Quote Share this post Link to post Share on other sites More sharing options...
nevermind86 Posted July 11, 2013 Report post Posted July 11, 2013 im just wondering, do you need R3 to have the ability to advertise to unknown machines? Quote Share this post Link to post Share on other sites More sharing options...
nevermind86 Posted July 11, 2013 Report post Posted July 11, 2013 i think ive become a little confused, do i need to advertise my windows image to a bare metal system or should it just pick it up, do i need to target unknown collection? Quote Share this post Link to post Share on other sites More sharing options...
nevermind86 Posted July 12, 2013 Report post Posted July 12, 2013 update: it works !! im a massive tool, i had missed the part where you deploy the wim image in its deploy task sequence (had missed the small URL at the bottom of the previouos document) sorry for wasting anyones time, also I would like to know hoever, is there a way to deploy this to any new mac address or soemthing similar as i dont particularly want to add a new mac each time i want to image a machine? Quote Share this post Link to post Share on other sites More sharing options...
nevermind86 Posted July 14, 2013 Report post Posted July 14, 2013 anybody know if its possible to allow unknown mac address to pickup the pxe boot? Quote Share this post Link to post Share on other sites More sharing options...
Rocket Man Posted July 14, 2013 Report post Posted July 14, 2013 Quote anybody know if its possible to allow unknown mac address to pickup the pxe boot? If you have unknown computer support enabled then yes. If you dont then you have to import the systems info(MAC and NetBIOS Name) into SCCM to allow it to PXE boot which the means your MAC address is no longer unknown. The first option is the easiest and most efficient way......with a DP password and a TS password it is almost as secure as a DP that does not allow unknown computer support! Quote Share this post Link to post Share on other sites More sharing options...
