BobbyB Posted July 11, 2013 Report post Posted July 11, 2013 I have recently inherited SCCM 2012 SP1 responsibility and started to work on a new model pc that we received. I'm having issues when i try to PXE and Run our Task Sequence to install Software,OS,ETC... I checked the logs to see what was causing it to fail and it shows it can't find partitioned disk. If i Select one of our 32 Bit TS it works fine.. and after it is partitioned from running 32Bit Ts 64 Bit will work no problem. I don't want to have to partition them then have to restart and install 64 Bit... I looked on the forum before i posted to make sure i wasn't posting something that is all ready out there. Any Ideas?? Thanks! Quote Share this post Link to post Share on other sites More sharing options...
Peter33 Posted July 12, 2013 Report post Posted July 12, 2013 You don't need a 64 bit boot Image to install a previously captured 64 Bit Image, as long you don't use UEFI boot. My advice: use MDT2012 and create a new MDT Task sequence. It has some built in steps for partitioning, even depending on your boot procedure (UEFI/Legacy). You could also simply a "clean disk" step to your Task sequnce just before the partitioning step. Quote Share this post Link to post Share on other sites More sharing options...
