ahmed226
SCCM 2007 not Installed properly
I installed SCCM 2007. At the end of installation process it shows a list of all the things it installed, but it mentioned Management Point, and next to it its status is: Unknown.
I did not bother extend the AD schema before the install. do you think its related to this? will i have to re-install SCCM?
thanks
thanks
Reasoning you didnt extend the AD Schema?
