Im getting task sequence drop out and 80004005 error when trying to build and capture an image of windows 7. The task sequence worked a week ago but have suddenly stopped but nothing has been changed at all.
The OS is downloaded, drivers downloaded then the drop-out occurs just as the Actual windows setup screen appears (blue background saying setting up windows", when the task sequence says "Setting up windows and configuration manager"
I have attached the log files I could find, path names from win pe are the file names.
If anyone could take a look it would be much appreciated
EDIT: After trying again I've found another log (the one just names smsts.log) file with some more errors if anyone can understand them?
HI all,
x-smstslog-smsts.logFetching info...
x-windows-temp-smstslog-smsts.logFetching info...
