sealesk
SCCM 2012 Client Issue on PC
You could use those switches on a PC/Server you need the client installed on using the command prompt.
CCMSetup.exe is the .exe file
/mp:<ServerName> is your Management Point Server
/logon stops the install if the client is already installed, so I'm not sure if I'd use that in your instance.
Check out the list here: http://technet.microsoft.com/en-us/library/gg699356.aspx
