morne4444
SCCM 2012 DP stuck "starting to process content"
Hi All
I am stuck with a problem in SCCM 2012. It is unable to distribute newly packaged content.
The DP just says "starting to process content" and doesnt change.
I have removed the DP from the server and re-added it.
Reinstalled IIS
Recreated the package(s)
Installed update http://support.microsoft.com/kb/2854009
I still have the issue, All the distmgr.log file says it "Package is already in the queue"
One thing to note:
I tested the DP by removing the SMSPKG (driveletter) $ share, but recreating the DP does not re-create this share.
This started mid July, no SCEP definitions are currently being deployed.
All work has been done on the Primary Site server, the data for the packages are also stored on this server.
Version 5.00.7804.1000
Build number 7804
Thank you
Morne
