bryeschen
SCCM 12 OSX Management Enrollment
When running the CMEroll command I get Server connection failed. HTTP Response code is 404 and reason is Not Found.
I feel as though something is not being installed properly, as I can not find any of the specific log files or directory's that I should be finding based on the documentation I am following.
Using these documents and following them exactly how there are.
http://www.jamesbannanit.com/2012/10/enrol-mac-os-x-clients-in-configuration-manager-2012-sp1/
http://technet.microsoft.com/en-us/library/jj591553.aspx
Searching in event viewer found me these errors:
In my Event Viewer>Windows Logs>Application
I get the following Error: Site Component Manager failed to re-install this component on the site system for the following task category.
SMS_MP_DEVICE_MANAGER
SMS_AWEBSVC_CONTROLMANAGER
SMS_ENROLL_SERVER
SMS_ENROLL_WEB
SMS_PORTALWEB_CONTROL_MANAGER
