andymc
VBscript - problem with adding membershiprule to collection
Hello at all,
I’m working on a script which creates a SCCM collection and appends a collection rule. The function createCollection creates and moves the collection without any problems.
The collection rule object is also created without any error codes, but at adding the collection rule (newCollection.AddMembershipRulenewCollectionRule) I get a “general error”.
Has anybody an idea how to fix this problem?
FunctioncreateCollection(collectionName)
    DimvalidQuery, queryExpr
'creates the collection.
    SetnewCollection=objSccm.Get("SMS_Collection").SpawnInstance_()
    newCollection.Name=collectionName
    newCollection.OwnedByThisSite=True
    newCollection.Comment="Comment"
    SetcollectionPath=newCollection.Put_
'AttemptstoobtainthecollectionIDofthenewlycreatedcollection.
SetCollection=objSccm.ExecQuery("select*fromSMS_CollectionwhereName='"&collectionName&"'")
ForeachobjCollectioninCollection
    strCollectionID=objCollection.CollectionID
Next
If
strCollectionID=""Then
    Wscript.Echo"UnabletoobtianacollectionIDforthenewlycreatedcollection."
    WScript.Quit
Else
    'Attemptstomovethenewlycreatedcollectionintothedesiredparentcollection.
    SetnewCollectionRelation=objSccm.Get("SMS_CollectToSubCollect").SpawnInstance_()
    newCollectionRelation.parentCollectionID=strParentCollectionID
    newCollectionRelation.subCollectionID=strCollectionID
    newCollectionRelation.Put_
EndIf
    'Attemptstocreateandaddthequeryrulegrouptothecollection!
    SetstdQuery=objSccm.Get("SMS_CollectionRuleQuery")
    validQuery=stdQuery.ValidateQuery(queryExpr)
    IfvalidQueryThen
    SetnewCollectionRule=stdQuery.SpawnInstance_
    newCollectionRule.QueryExpression=queryExpr
    newCollectionRule.RuleName="Rulename"
    SetnewCollection=objSccm.Get(collectionPath.RelPath)
    newCollection.RequestRefreshFalse
EndIf
EndFunction
Problem is solved.The code is okay and working.
The script tried to create a query rule which is not limited to a collection (the same like a limitation to "All Systems"), but the executing account was not permitted to read values from "All Systems" collection.
