Kookers
Help with Custom HTA
I have been over the code and modified it as needed, but it will not actually Call the Optional Software. Can someone please tell me what I am missing.
The HTA runs and allows me to set the computer name and select the Optional Applications, the OSD Continues, and completes but no applications are installed.
Here is the HTA Code:
<head>
<title>My Company - SCCM Deployment</title>
<body STYLE="font:10 pt arial; color:white; background-color: #0000FF">
<HTA:APPLICATION
APPLICATIONNAME="My Company - SCCM Deployment"
SCROLL="yes"
SINGLEINSTANCE="yes"
BORDER="no"
BORDERSTYLE="raised"
MAXIMIZEBUTTON="no"
MINIMIZEBUTTON="no"
NAVIGATABLE="no"
</head>
<SCRIPT LANGUAGE="VBScript">
sub DoResize
'resize
window.resizeTo 600,600
screenWidth = Document.ParentWindow.Screen.AvailWidth
screenHeight = Document.ParentWindow.Screen.AvailHeight
posLeft = (screenWidth - 700) / 2
posTop = (screenHeight - 430) / 2
'move to centerscreen
window.moveTo posLeft, posTop
end sub
DoResize() ' run the subroutine to position the containing window (your HTA dialog) before the body is rendered.
sub Window_onLoad()
iTimerID = window.setInterval("checkempty", 100, "VBScript")
end sub
sub checkempty()
if computerName.value="" then
run_button.Disabled=true
else
run_button.Disabled=false
end if
end sub
'Hides Task Sequence Progress
Set ProgressUI = CreateObject("Microsoft.SMS.TsProgressUI")
ProgressUI.CloseProgressDialog
'Sets up actions to follow clicking on run
Sub ButtonFinish
dim InstallAcrobatPro9
dim InstallAvaya
dim InstallProject2010
dim InstallVisio2010
dim InstallOnDemand
dim InstallExceed
dim InstallIseries
dim InstallManu
dim InstallCA
dim InstallInform
dim InstallToad
dim InstallAllOptional
dim objLanguageButton
SET TSEnv = CreateObject("Microsoft.SMS.TSEnvironment")
'Sets PC Name
msgbox "PC NAME "& computername.Value &""
TSenv("OSDComputerName") = computername.Value
'Sets Variable For Acrobat Adobe Pro 9 Application
If InstallAdobePro9check.Checked Then
InstallAcrobatPro9 = "Y"
Else
InstallAcrobatPro9 = "N"
End If
TSEnv("Install-AcrobatPro9") = InstallAcrobatPro9
'Sets Variable For Avaya One-X Communicator Application
If InstallAvayaCheck.Checked Then
InstallAvaya = "Y"
Else
InstallAvaya = "N"
End If
TSEnv("Install-Avaya") = InstallCiscoAvaya
'Sets Variable For Project 2010 Application
If InstallProject2010check.Checked Then
InstallProject2010 = "Y"
Else
InstallProject2010 = "N"
End If
TSEnv("Install-Project2010") = InstallProject2010
'Sets Variable For Microsoft Visio 2010 Application
If InstallVisio2010check.Checked Then
InstallVisio2010 = "Y"
Else
InstallVisio2010 = "N"
End If
TSEnv("Install-Visio2010") = InstallVisio2010
'Sets Variable For Exceed On Demand
If InstallOnDemandCheck.Checked Then
InstallOnDemand = "Y"
Else
InstallOnDemand = "N"
End If
TSEnv("Install-OnDemand") = InstallOnDemand
'Sets Variable For Exceed Full
If InstallExceedCheck.Checked Then
InstallExceed = "Y"
Else
InstallExceed = "N"
End If
TSEnv("Install-Exceed") = InstallExceed
'Sets Variable For iSeries Client Access
If InstallIseriesCheck.Checked Then
InstallISeries = "Y"
Else
InstallISeries = "N"
End If
TSEnv("Install-ISeries") = InstallISeries
'Sets Variable For Manugistics
If InstallManuCheck.Checked Then
InstallManu = "Y"
Else
InstallManu = "N"
End If
TSEnv("Install-Manu") = InstallManu
'Sets Variable For CA Workload Automation
If InstallCACheck.Checked Then
InstallCA = "Y"
Else
InstallCA = "N"
End If
TSEnv("Install-CA") = InstallCA
'Sets Variable For Informatica
If InstallInformCheck.Checked Then
InstallInform = "Y"
Else
InstallInform = "N"
End If
TSEnv("Install-Inform") = InstallInform
'Sets Variable For Toad
If InstallToadCheck.Checked Then
InstallToad = "Y"
Else
InstallToad = "N"
End If
TSEnv("Install-Toad") = InstallToad
'Sets Variable For Install All Optional Software
If InstallAllOptionalCheck.Checked Then
InstallAllOptional = "Y"
Else
InstallAllOptional = "N"
End If
TSEnv("Install-AllOptional") = InstallAllOptional
'Sets Variable For Locale Language
For Each objLanguageButton in Installlocaleradio
If objLanguageButton.Checked Then
TSEnv("Install-Locale") = CStr(objLanguageButton.Value)
End If
Next
'Closes window
window.Close
End Sub
</SCRIPT>
<body>
<TEXT><b>Computer Name </b><FONT COLOR=#FF0000>*Required*</FONT></TEXT><br>
<input type=text id="computerName" name=computerName size=40><br>
<br><B>Optional Applications to Install    <FONT COLOR=#FF0000>*Not in Use, Coming Soon*</FONT></B></br>
<input type="checkbox" name="InstallAdobePro9Check">Install Adobe Acrobat Pro 9<br>
<input type="checkbox" name="InstallAvayaCheck">Install Avaya One-X Communicator<br>
<input type="checkbox" name="InstallProject2010check">Install Microsoft Project<br>
<input type="checkbox" name="InstallVisio2010check">Install Microsoft Visio<br>
<input type="checkbox" name="InstallOnDemandCheck">Install Exceed On Demand<br>
<input type="checkbox" name="InstallExceedCheck">Install Exceed Full<br>
<input type="checkbox" name="InstallIseriesCheck">Install iSeries Client Access<br>
<input type="checkbox" name="InstallManuCheck">Install Manugistics<br>
<input type="checkbox" name="InstallCACheck">Install CA Workload Automation<br>
<input type="checkbox" name="InstallInformCheck">Install Informatica<br>
<input type="checkbox" name="InstallToadCheck">Install Toad<br>
<input type="checkbox" name="InstallAllOptionalCheck">Install All Optional Software<br>
<br><B>Please Select Language   <FONT COLOR=#FF0000>*Not in Use, Coming Soon*</FONT></B></br>
<input type="radio" name="Installlocaleradio" value="en-us" checked>English<br>
<input type="radio" name="Installlocaleradio" value="gr-de">German<br>
<input type="radio" name="Installlocaleradio" value="ch-chs">Chinese (Simplified)<br>
<input type="radio" name="Installlocaleradio" value="ch-cht">Chinese (Traditional)<br>
<input type="radio" name="Installlocaleradio" value="jp-jp">Japanese<br><p>
<input id=runbutton type="button" value="Run Image Process" name="run_button" onClick="ButtonFinish">
</body>
TS part 1 of 2.pdfFetching info...
TS part 2 of 2.pdfFetching info...
0 answers to this question
