pamulli Posted August 16, 2013 Report post Posted August 16, 2013 I'm trying to capture a Windows 2008 R2 server that is running Citrix and I'm using a Capture disk. The server is in a workgroup and the SCCM agent is installed. I'm using the same boot image that was used to lay the image down so the driver should be good. Here is the SMSTS.log contents <![LOG[==============================[ TSMBootStrap.exe ]==============================]LOG]!><time="15:26:46.641+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmbootstrap.cpp:1129"> <![LOG[Command line: TSMBootstrap.exe /env:FullOS ]LOG]!><time="15:26:46.641+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmbootstrap.cpp:1130"> <![LOG[Executing from Media in Full OS]LOG]!><time="15:26:47.436+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmbootstrap.cpp:909"> <![LOG[Verifying Media Layout.]LOG]!><time="15:26:47.592+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:1581"> <![LOG[MediaType = FullMedia]LOG]!><time="15:26:47.811+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:2565"> <![LOG[PasswordRequired = false]LOG]!><time="15:26:47.811+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:2591"> <![LOG[Executing stand-alone media in full operating system on a machine that is running a Configuration Manager client. ]LOG]!><time="15:26:47.967+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:2711"> <![LOG[user has sufficient security rights to create a service.]LOG]!><time="15:26:47.967+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmbootstraputil.cpp:419"> <![LOG[Running Wizard in Unattended mode]LOG]!><time="15:26:47.967+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:2761"> <![LOG[Loading Media Variables from "D:\sms\data\variables.dat"]LOG]!><time="15:26:48.279+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsremovablemedia.cpp:322"> <![LOG[no password for vars file]LOG]!><time="15:26:49.106+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:247"> <![LOG[Environment scope successfully created: Global\{51A016B6-F0DE-4752-B97C-54E6F386A912}]LOG]!><time="15:26:49.121+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="environmentscope.cpp:659"> <![LOG[Environment scope successfully created: Global\{BA3A3900-CA6D-4ac1-8C28-5073AFC22B03}]LOG]!><time="15:26:49.121+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="environmentscope.cpp:659"> <![LOG[uEFI: false]LOG]!><time="15:26:49.262+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:569"> <![LOG[Loading variables from the Task Sequencing Removable Media.]LOG]!><time="15:26:49.262+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:584"> <![LOG[Loading Media Variables from "D:\sms\data\variables.dat"]LOG]!><time="15:26:49.262+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsremovablemedia.cpp:322"> <![LOG[Root CA Public Certs=]LOG]!><time="15:26:49.371+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:615"> <![LOG[support Unknown Machines: 1]LOG]!><time="15:26:49.371+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:632"> <![LOG[Custom hook from D:\\TSConfig.INI is ]LOG]!><time="15:26:49.542+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:675"> <![LOG[No hook is found to be executed before downloading policy]LOG]!><time="15:26:49.542+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:699"> <![LOG[Loading policy from D:\sms\data\Policy.XML.]LOG]!><time="15:26:51.102+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:718"> <![LOG[Loading policy from file: D:\sms\data\Policy.XML]LOG]!><time="15:26:51.414+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tspolicy.cpp:1046"> <![LOG[This Task sequence is set for RunFromDP]LOG]!><time="15:26:53.240+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tspolicy.cpp:3155"> <![LOG[Retrieving collection variable policy.]LOG]!><time="15:26:53.396+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tspolicy.cpp:1512"> <![LOG[Found 0 collection variables.]LOG]!><time="15:26:53.396+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tspolicy.cpp:1520"> <![LOG[Retrieving machine variable policy.]LOG]!><time="15:26:53.396+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tspolicy.cpp:1530"> <![LOG[Found 0 machine variables.]LOG]!><time="15:26:53.396+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tspolicy.cpp:1538"> <![LOG[setting collection variables in the task sequencing environment.]LOG]!><time="15:26:53.723+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="utils.cpp:157"> <![LOG[setting machine variables in the task sequencing environment.]LOG]!><time="15:26:53.723+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="utils.cpp:157"> <![LOG[Creating the Task Sequencing Environment.]LOG]!><time="15:26:53.723+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1487"> <![LOG[setting Media Variables in Task Sequencing Environment.]LOG]!><time="15:26:53.723+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1492"> <![LOG[Resolving content location for selected task sequence.]LOG]!><time="15:26:53.723+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tspolicy.cpp:3377"> <![LOG[Task sequence content location: ]LOG]!><time="15:26:53.723+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tspolicy.cpp:3383"> <![LOG[Getting policy for CCM_SoftwareDistribution[AdvertID={F59EE054-6C84-4BBA-A8FB-398FC31BD87C}", PackageID="HOK00008", ProgramID="*]]LOG]!><time="15:26:53.723+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tspolicy.cpp:2430"> <![LOG[successfully resolved policy for HOK00008.]LOG]!><time="15:26:53.879+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tspolicy.cpp:2558"> <![LOG[Resolving content location for HOK00008]LOG]!><time="15:26:53.879+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tspolicy.cpp:2575"> <![LOG[HOK00008 content location: file:VOL001:\SMS\PKG\HOK00008]LOG]!><time="15:26:54.035+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tspolicy.cpp:2642"> <![LOG[No need to register providers]LOG]!><time="15:26:54.035+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmbootstraputil.cpp:1000"> <![LOG[Registering the Progress UI.]LOG]!><time="15:26:54.035+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1726"> <![LOG[Executing command line: "D:\SMS\BIN\x64\TsProgressUI.exe" /Register]LOG]!><time="15:26:54.410+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="commandline.cpp:827"> <![LOG[==========[ TsProgressUI started in process 6584 ]==========]LOG]!><time="15:26:56.235+300" date="08-16-2013" component="TsProgressUI" context="" type="1" thread="6368" file="winmain.cpp:330"> <![LOG[Registering COM classes]LOG]!><time="15:26:56.235+300" date="08-16-2013" component="TsProgressUI" context="" type="1" thread="6368" file="winmain.cpp:187"> <![LOG[sbModulePath = D:\SMS\BIN\x64\TsProgressUI.exe]LOG]!><time="15:26:56.235+300" date="08-16-2013" component="TsProgressUI" context="" type="1" thread="6368" file="tsprogressuiclass.cpp:625"> <![LOG[shutdown complete.]LOG]!><time="15:26:56.250+300" date="08-16-2013" component="TsProgressUI" context="" type="1" thread="6368" file="winmain.cpp:512"> <![LOG[Process completed with exit code 0]LOG]!><time="15:26:56.250+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="commandline.cpp:1123"> <![LOG[successfully registered TS Progress UI.]LOG]!><time="15:26:56.250+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="utils.cpp:2279"> <![LOG[setting Media Variables in Task Sequencing Environment.]LOG]!><time="15:26:56.250+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1739"> <![LOG[setting WinPE Flag in the Task Sequencing Environment.]LOG]!><time="15:26:56.266+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1763"> <![LOG[setting Media Type Flag in the Task Sequencing Environment.]LOG]!><time="15:26:56.266+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1769"> <![LOG[setting Local Computer Name in the Task Sequencing Environment.]LOG]!><time="15:26:56.266+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1775"> <![LOG[setting Selected Task Sequence Information Task Sequencing Environment.]LOG]!><time="15:26:56.266+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1782"> <![LOG[setting selected task sequence information in the environment.]LOG]!><time="15:26:56.266+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tspolicy.cpp:3490"> <![LOG[setting source for HOK00008 to file:VOL001:\SMS\PKG\HOK00008]LOG]!><time="15:26:56.562+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="resolvesource.cpp:3729"> <![LOG[setting _SMSTSPKGFLAGSHOK00008 to 0]LOG]!><time="15:26:56.562+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tspolicy.cpp:3653"> <![LOG[initializing the local data path.]LOG]!><time="15:26:56.562+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1788"> <![LOG[Windows To Go requires a minimum operating system of Windows 8]LOG]!><time="15:26:57.030+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="utils.cpp:1283"> <![LOG[Volume C:\ has attributes 0x00000000]LOG]!><time="15:27:01.913+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="utils.cpp:437"> <![LOG[C:\_SMSTaskSequence folder exists, removing]LOG]!><time="15:27:02.069+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="utils.cpp:1161"> <![LOG[updated security on object C:\_SMSTaskSequence.]LOG]!><time="15:27:02.069+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="utils.cpp:1121"> <![LOG[setting Task Sequence User State Path to "%_SMSTSMDataPath%\UserState".]LOG]!><time="15:27:02.069+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:145"> <![LOG[setting Network Access Account Information in Task Sequencing Environment.]LOG]!><time="15:27:02.069+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1811"> <![LOG[Cannot find NAAConfig CCM_NetworkAccessAccount]LOG]!><time="15:27:02.069+300" date="08-16-2013" component="TSMBootstrap" context="" type="2" thread="3540" file="tspolicy.cpp:1737"> <![LOG[Network Access Account is not set]LOG]!><time="15:27:02.069+300" date="08-16-2013" component="TSMBootstrap" context="" type="2" thread="3540" file="tspolicy.h:179"> <![LOG[unable to get Network Access Account. Ignoring.]LOG]!><time="15:27:02.069+300" date="08-16-2013" component="TSMBootstrap" context="" type="2" thread="3540" file="tsmediawizardcontrol.cpp:1820"> <![LOG[Found property CCM_ClientAgentConfig.BrandingTitle = HOK]LOG]!><time="15:27:02.069+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tspolicy.cpp:1706"> <![LOG[setting Client ID in Task Sequencing Environment.]LOG]!><time="15:27:02.069+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1845"> <![LOG[setting machine name from SMS database.]LOG]!><time="15:27:02.069+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1860"> <![LOG[Failed to retrieve the machine name from SMS database. Fall back to the current local computer name.]LOG]!><time="15:27:02.069+300" date="08-16-2013" component="TSMBootstrap" context="" type="2" thread="3540" file="tsmediawizardcontrol.cpp:1869"> <![LOG[setting SysHealthConfig policy in the environment.]LOG]!><time="15:27:02.069+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1874"> <![LOG[setting SoftUpdConfig policy in the environment.]LOG]!><time="15:27:02.085+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1882"> <![LOG[setting SoftDistClient config policy in the environment.]LOG]!><time="15:27:02.085+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1890"> <![LOG[setting software update policy in the environment.]LOG]!><time="15:27:02.085+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1898"> <![LOG[setting software update policy in the environment.]LOG]!><time="15:27:02.085+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1906"> <![LOG[setting quarantine policy in the environment.]LOG]!><time="15:27:02.085+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1914"> <![LOG[setting NAAConfig policy in the environment.]LOG]!><time="15:27:02.085+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1922"> <![LOG[setting CIVersionInfo policy in the environment.]LOG]!><time="15:27:02.085+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1930"> <![LOG[setting RebootSettingsConfig policy in the environment.]LOG]!><time="15:27:02.085+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1939"> <![LOG[setting AppManClientConfig policy in the environment.]LOG]!><time="15:27:02.085+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="3540" file="tsmediawizardcontrol.cpp:1947"> <![LOG[Media root drive is: D:\]LOG]!><time="15:27:02.085+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:2001"> <![LOG[setting launch mode to: CD]LOG]!><time="15:27:02.085+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:2019"> <![LOG[copying files from d:\ to C:\_SMSTaskSequence]LOG]!><time="15:27:02.085+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="3540" file="tsmediawizardcontrol.cpp:2054"> <![LOG[==============================[ TSMBootStrap.exe ]==============================]LOG]!><time="15:31:53.355+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmbootstrap.cpp:1129"> <![LOG[Command line: TSMBootstrap.exe /env:FullOS ]LOG]!><time="15:31:53.371+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmbootstrap.cpp:1130"> <![LOG[Executing from Media in Full OS]LOG]!><time="15:31:54.962+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmbootstrap.cpp:909"> <![LOG[Verifying Media Layout.]LOG]!><time="15:31:55.274+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:1581"> <![LOG[MediaType = FullMedia]LOG]!><time="15:31:55.539+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:2565"> <![LOG[PasswordRequired = false]LOG]!><time="15:31:55.539+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:2591"> <![LOG[Executing stand-alone media in full operating system on a machine that is running a Configuration Manager client. ]LOG]!><time="15:31:55.695+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:2711"> <![LOG[user has sufficient security rights to create a service.]LOG]!><time="15:31:56.460+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmbootstraputil.cpp:419"> <![LOG[Running Wizard in Unattended mode]LOG]!><time="15:31:56.460+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:2761"> <![LOG[Loading Media Variables from "D:\sms\data\variables.dat"]LOG]!><time="15:31:56.756+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsremovablemedia.cpp:322"> <![LOG[no password for vars file]LOG]!><time="15:31:57.598+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:247"> <![LOG[Environment scope successfully created: Global\{51A016B6-F0DE-4752-B97C-54E6F386A912}]LOG]!><time="15:31:57.614+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="environmentscope.cpp:659"> <![LOG[Environment scope successfully created: Global\{BA3A3900-CA6D-4ac1-8C28-5073AFC22B03}]LOG]!><time="15:31:57.614+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="environmentscope.cpp:659"> <![LOG[uEFI: false]LOG]!><time="15:31:57.754+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:569"> <![LOG[Loading variables from the Task Sequencing Removable Media.]LOG]!><time="15:31:57.754+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:584"> <![LOG[Loading Media Variables from "D:\sms\data\variables.dat"]LOG]!><time="15:31:57.754+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsremovablemedia.cpp:322"> <![LOG[Root CA Public Certs=]LOG]!><time="15:31:57.864+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:615"> <![LOG[support Unknown Machines: 1]LOG]!><time="15:31:57.864+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:632"> <![LOG[Custom hook from D:\\TSConfig.INI is ]LOG]!><time="15:31:57.864+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:675"> <![LOG[No hook is found to be executed before downloading policy]LOG]!><time="15:31:57.864+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:699"> <![LOG[Loading policy from D:\sms\data\Policy.XML.]LOG]!><time="15:31:59.392+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:718"> <![LOG[Loading policy from file: D:\sms\data\Policy.XML]LOG]!><time="15:31:59.704+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tspolicy.cpp:1046"> <![LOG[This Task sequence is set for RunFromDP]LOG]!><time="15:32:01.389+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tspolicy.cpp:3155"> <![LOG[Retrieving collection variable policy.]LOG]!><time="15:32:01.530+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tspolicy.cpp:1512"> <![LOG[Found 0 collection variables.]LOG]!><time="15:32:01.530+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tspolicy.cpp:1520"> <![LOG[Retrieving machine variable policy.]LOG]!><time="15:32:01.530+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tspolicy.cpp:1530"> <![LOG[Found 0 machine variables.]LOG]!><time="15:32:01.530+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tspolicy.cpp:1538"> <![LOG[setting collection variables in the task sequencing environment.]LOG]!><time="15:32:01.857+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="utils.cpp:157"> <![LOG[setting machine variables in the task sequencing environment.]LOG]!><time="15:32:01.857+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="utils.cpp:157"> <![LOG[Creating the Task Sequencing Environment.]LOG]!><time="15:32:01.857+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1487"> <![LOG[setting Media Variables in Task Sequencing Environment.]LOG]!><time="15:32:01.857+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1492"> <![LOG[Resolving content location for selected task sequence.]LOG]!><time="15:32:01.857+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tspolicy.cpp:3377"> <![LOG[Task sequence content location: ]LOG]!><time="15:32:01.857+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tspolicy.cpp:3383"> <![LOG[Getting policy for CCM_SoftwareDistribution[AdvertID={F59EE054-6C84-4BBA-A8FB-398FC31BD87C}", PackageID="HOK00008", ProgramID="*]]LOG]!><time="15:32:01.857+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tspolicy.cpp:2430"> <![LOG[successfully resolved policy for HOK00008.]LOG]!><time="15:32:02.013+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tspolicy.cpp:2558"> <![LOG[Resolving content location for HOK00008]LOG]!><time="15:32:02.013+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tspolicy.cpp:2575"> <![LOG[HOK00008 content location: file:VOL001:\SMS\PKG\HOK00008]LOG]!><time="15:32:02.169+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tspolicy.cpp:2642"> <![LOG[No need to register providers]LOG]!><time="15:32:02.169+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmbootstraputil.cpp:1000"> <![LOG[Registering the Progress UI.]LOG]!><time="15:32:02.169+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1726"> <![LOG[Executing command line: "D:\SMS\BIN\x64\TsProgressUI.exe" /Register]LOG]!><time="15:32:02.528+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="commandline.cpp:827"> <![LOG[==========[ TsProgressUI started in process 400 ]==========]LOG]!><time="15:32:04.119+300" date="08-16-2013" component="TsProgressUI" context="" type="1" thread="4568" file="winmain.cpp:330"> <![LOG[Registering COM classes]LOG]!><time="15:32:04.119+300" date="08-16-2013" component="TsProgressUI" context="" type="1" thread="4568" file="winmain.cpp:187"> <![LOG[sbModulePath = D:\SMS\BIN\x64\TsProgressUI.exe]LOG]!><time="15:32:04.119+300" date="08-16-2013" component="TsProgressUI" context="" type="1" thread="4568" file="tsprogressuiclass.cpp:625"> <![LOG[shutdown complete.]LOG]!><time="15:32:04.135+300" date="08-16-2013" component="TsProgressUI" context="" type="1" thread="4568" file="winmain.cpp:512"> <![LOG[Process completed with exit code 0]LOG]!><time="15:32:04.150+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="commandline.cpp:1123"> <![LOG[successfully registered TS Progress UI.]LOG]!><time="15:32:04.150+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="utils.cpp:2279"> <![LOG[setting Media Variables in Task Sequencing Environment.]LOG]!><time="15:32:04.150+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1739"> <![LOG[setting WinPE Flag in the Task Sequencing Environment.]LOG]!><time="15:32:04.150+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1763"> <![LOG[setting Media Type Flag in the Task Sequencing Environment.]LOG]!><time="15:32:04.150+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1769"> <![LOG[setting Local Computer Name in the Task Sequencing Environment.]LOG]!><time="15:32:04.150+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1775"> <![LOG[setting Selected Task Sequence Information Task Sequencing Environment.]LOG]!><time="15:32:04.150+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1782"> <![LOG[setting selected task sequence information in the environment.]LOG]!><time="15:32:04.150+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tspolicy.cpp:3490"> <![LOG[setting source for HOK00008 to file:VOL001:\SMS\PKG\HOK00008]LOG]!><time="15:32:04.306+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="resolvesource.cpp:3729"> <![LOG[setting _SMSTSPKGFLAGSHOK00008 to 0]LOG]!><time="15:32:04.306+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tspolicy.cpp:3653"> <![LOG[initializing the local data path.]LOG]!><time="15:32:04.306+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1788"> <![LOG[Windows To Go requires a minimum operating system of Windows 8]LOG]!><time="15:32:04.759+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="utils.cpp:1283"> <![LOG[Volume C:\ has attributes 0x00000000]LOG]!><time="15:32:22.340+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="utils.cpp:437"> <![LOG[C:\_SMSTaskSequence folder exists, removing]LOG]!><time="15:32:22.481+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="utils.cpp:1161"> <![LOG[updated security on object C:\_SMSTaskSequence.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="utils.cpp:1121"> <![LOG[setting Task Sequence User State Path to "%_SMSTSMDataPath%\UserState".]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:145"> <![LOG[setting Network Access Account Information in Task Sequencing Environment.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1811"> <![LOG[Cannot find NAAConfig CCM_NetworkAccessAccount]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="2" thread="5944" file="tspolicy.cpp:1737"> <![LOG[Network Access Account is not set]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="2" thread="5944" file="tspolicy.h:179"> <![LOG[unable to get Network Access Account. Ignoring.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="2" thread="5944" file="tsmediawizardcontrol.cpp:1820"> <![LOG[Found property CCM_ClientAgentConfig.BrandingTitle = HOK]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tspolicy.cpp:1706"> <![LOG[setting Client ID in Task Sequencing Environment.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1845"> <![LOG[setting machine name from SMS database.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1860"> <![LOG[Failed to retrieve the machine name from SMS database. Fall back to the current local computer name.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="2" thread="5944" file="tsmediawizardcontrol.cpp:1869"> <![LOG[setting SysHealthConfig policy in the environment.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1874"> <![LOG[setting SoftUpdConfig policy in the environment.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1882"> <![LOG[setting SoftDistClient config policy in the environment.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1890"> <![LOG[setting software update policy in the environment.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1898"> <![LOG[setting software update policy in the environment.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1906"> <![LOG[setting quarantine policy in the environment.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1914"> <![LOG[setting NAAConfig policy in the environment.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1922"> <![LOG[setting CIVersionInfo policy in the environment.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1930"> <![LOG[setting RebootSettingsConfig policy in the environment.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1939"> <![LOG[setting AppManClientConfig policy in the environment.]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="tsmediawizardcontrol.cpp:1947"> <![LOG[Media root drive is: D:\]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:2001"> <![LOG[setting launch mode to: CD]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:2019"> <![LOG[copying files from d:\ to C:\_SMSTaskSequence]LOG]!><time="15:32:22.512+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:2054"> <![LOG[Executing command line: OsdCaptureCD.exe]LOG]!><time="15:33:39.945+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="commandline.cpp:827"> <![LOG[==============================[ OSDCaptureCD.exe ]==============================]LOG]!><time="15:33:40.054+300" date="08-16-2013" component="OSDCaptureCD" context="" type="1" thread="8708" file="osdcapturecd.cpp:114"> <![LOG[Command line: "OsdCaptureCD.exe"]LOG]!><time="15:33:40.054+300" date="08-16-2013" component="OSDCaptureCD" context="" type="0" thread="8708" file="osdcapturecd.cpp:115"> <![LOG[Loading vista instructions.]LOG]!><time="15:33:40.085+300" date="08-16-2013" component="OSDCaptureCD" context="" type="0" thread="8708" file="welcomepage.cpp:63"> <![LOG[Activating Welcome Page.]LOG]!><time="15:33:40.085+300" date="08-16-2013" component="OSDCaptureCD" context="" type="0" thread="8708" file="welcomepage.cpp:92"> <![LOG[Verifying that this machine meets the capture requirements.]LOG]!><time="15:34:39.997+300" date="08-16-2013" component="OSDCaptureCD" context="" type="1" thread="8708" file="welcomepage.cpp:141"> <![LOG[Local machine is not a domain controller.]LOG]!><time="15:34:39.997+300" date="08-16-2013" component="OSDCaptureCD" context="" type="1" thread="8708" file="deployutil.cpp:569"> <![LOG[system partition is NTFS]LOG]!><time="15:34:39.997+300" date="08-16-2013" component="OSDCaptureCD" context="" type="1" thread="8708" file="deployutil.cpp:494"> <![LOG[Verified deploy tools are present.]LOG]!><time="15:34:39.997+300" date="08-16-2013" component="OSDCaptureCD" context="" type="1" thread="8708" file="deployutil.cpp:415"> <![LOG[Local machine is not part of a domain]LOG]!><time="15:34:40.013+300" date="08-16-2013" component="OSDCaptureCD" context="" type="1" thread="8708" file="deployutil.cpp:534"> <![LOG[Activating Destination Page.]LOG]!><time="15:34:40.013+300" date="08-16-2013" component="OSDCaptureCD" context="" type="0" thread="8708" file="destinationpage.cpp:97"> <![LOG[Verifying credentials can be used to write image file.]LOG]!><time="15:36:34.065+300" date="08-16-2013" component="OSDCaptureCD" context="" type="1" thread="8708" file="wizardcontrol.cpp:428"> <![LOG[Deleting any existing network connections to "\\ny-ren-d001\Image\*".]LOG]!><time="15:36:34.065+300" date="08-16-2013" component="OSDCaptureCD" context="" type="0" thread="8708" file="wizardcontrol.cpp:432"> <![LOG[Verifying connection to: \\ny-ren-d001\Image]LOG]!><time="15:36:34.065+300" date="08-16-2013" component="OSDCaptureCD" context="" type="0" thread="8708" file="wizardcontrol.cpp:440"> <![LOG[Connection to "\\ny-ren-d001\Image" failed with credential conflict. Using existing connection.]LOG]!><time="15:36:49.072+300" date="08-16-2013" component="OSDCaptureCD" context="" type="2" thread="8708" file="tsconnection.cpp:328"> <![LOG[Activating Welcome Page.]LOG]!><time="15:36:49.072+300" date="08-16-2013" component="OSDCaptureCD" context="" type="0" thread="8708" file="infopage.cpp:68"> <![LOG[Activating Finish Page.]LOG]!><time="15:36:59.477+300" date="08-16-2013" component="OSDCaptureCD" context="" type="0" thread="8708" file="finishpage.cpp:59"> <![LOG[saving capture information in the environment.]LOG]!><time="15:37:03.252+300" date="08-16-2013" component="OSDCaptureCD" context="" type="1" thread="8708" file="wizardcontrol.cpp:499"> <![LOG[Exiting with return code 0x00000000]LOG]!><time="15:37:03.268+300" date="08-16-2013" component="OSDCaptureCD" context="" type="1" thread="8708" file="osdcapturecd.cpp:157"> <![LOG[Process completed with exit code 0]LOG]!><time="15:37:03.284+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="commandline.cpp:1123"> <![LOG[Creating the TS Manager Service.]LOG]!><time="15:37:03.284+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:2277"> <![LOG[starting Task Sequence Manager Service.]LOG]!><time="15:37:03.455+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmediawizardcontrol.cpp:2283"> <![LOG[Modifying TS Manager Service to auto start.]LOG]!><time="15:37:03.455+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="utils.cpp:2016"> <![LOG[starting the TS Manager Service.]LOG]!><time="15:37:03.471+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="utils.cpp:2103"> <![LOG[successfully intialized Logging for TS Manager.]LOG]!><time="15:37:03.611+300" date="08-16-2013" component="TSManager" context="" type="1" thread="7764" file="tsmanager.cpp:705"> <![LOG[Commandline: "C:\_SMSTaskSequence\sms\bin\x64\TsManager.exe" /service /noclient /loghandle 5756 588]LOG]!><time="15:37:03.627+300" date="08-16-2013" component="TSManager" context="" type="1" thread="7764" file="tsmanager.cpp:60"> <![LOG[successfully registered Task Sequencing COM Interface.]LOG]!><time="15:37:03.642+300" date="08-16-2013" component="TSManager" context="" type="1" thread="7764" file="environmentlib.cpp:799"> <![LOG[Executing as a service]LOG]!><time="15:37:03.642+300" date="08-16-2013" component="TSManager" context="" type="1" thread="7764" file="tsmanager.cpp:718"> <![LOG[started ServiceMain]LOG]!><time="15:37:03.642+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="tsmanager.cpp:295"> <![LOG[Waiting for the TS Manager Service to start.]LOG]!><time="15:37:03.642+300" date="08-16-2013" component="TSMBootstrap" context="" type="0" thread="5944" file="utils.cpp:2110"> <![LOG[Task Sequence Manager executing as service main thread]LOG]!><time="15:37:03.658+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="tsmanager.cpp:419"> <![LOG[Deleting volume ID file C:\_SMSTSVolumeID.7159644d-f741-45d5-ab29-0ad8aa4771ca ...]LOG]!><time="15:37:03.658+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="resolvesource.cpp:519"> <![LOG[Task Sequencing Manager Service successfully started.]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="utils.cpp:2115"> <![LOG[Parsing task sequence . . .]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="tsmanager.cpp:1370"> <![LOG[Exiting with return code 0x00000000]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSMBootstrap" context="" type="1" thread="5944" file="tsmbootstrap.cpp:1195"> <![LOG[Task sequence schema version is 3.00]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="tsmanager.cpp:1301"> <![LOG[Current supported schema version is 3.10 and 3.00]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="tsmanager.cpp:1309"> <![LOG[No variables found in default variable list]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="tsxml.cpp:606"> <![LOG[starting Task Sequence Engine . . . ]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="tsmanager.cpp:857"> <![LOG[****************************************************************************]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="tsmanager.cpp:859"> <![LOG[set a global environment variable _SMSTSNextInstructionPointer=0]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a global environment variable _SMSTSInstructionTableSize=6]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a global environment variable SMSTSRebootRequested=]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a global environment variable SMSTSRebootDelay=]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a global environment variable SMSTSRebootMessage=]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a global environment variable SMSTSRebootReason=]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a global environment variable SMSTSRetryRequested=]LOG]!><time="15:37:03.689+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[The task execution engine started execution]LOG]!><time="15:37:03.705+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="engine.cxx:70"> <![LOG[Do not send status message in full media case]LOG]!><time="15:37:03.705+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="utils.cpp:5182"> <![LOG[Do not send status message in full media case]LOG]!><time="15:37:03.705+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="utils.cpp:5182"> <![LOG[start executing an instruction. Instruction name: Capture the Reference Machine. Instruction pointer: 0]LOG]!><time="15:37:03.705+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="engine.cxx:117"> <![LOG[set a global environment variable _SMSTSCurrentActionName=Capture the Reference Machine]LOG]!><time="15:37:03.705+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a global environment variable _SMSTSNextInstructionPointer=0]LOG]!><time="15:37:03.705+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[The group (Capture the Reference Machine) has been successfully started]LOG]!><time="15:37:03.845+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="instruction.cxx:2364"> <![LOG[Do not send status message in full media case]LOG]!><time="15:37:03.845+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="utils.cpp:5182"> <![LOG[updated security on object C:\_SMSTaskSequence.]LOG]!><time="15:37:03.861+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="utils.cpp:1121"> <![LOG[set a global environment variable _SMSTSNextInstructionPointer=1]LOG]!><time="15:37:03.861+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a TS execution environment variable _SMSTSNextInstructionPointer=1]LOG]!><time="15:37:03.861+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:386"> <![LOG[set a global environment variable _SMSTSInstructionStackString=0]LOG]!><time="15:37:03.861+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a TS execution environment variable _SMSTSInstructionStackString=0]LOG]!><time="15:37:03.861+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:414"> <![LOG[save the current environment block]LOG]!><time="15:37:03.861+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:833"> <![LOG[start executing an instruction. Instruction name: Prepare Configuration Manager Client. Instruction pointer: 1]LOG]!><time="15:37:03.892+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="engine.cxx:117"> <![LOG[set a global environment variable _SMSTSCurrentActionName=Prepare Configuration Manager Client]LOG]!><time="15:37:03.892+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a global environment variable _SMSTSNextInstructionPointer=1]LOG]!><time="15:37:03.892+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a global environment variable _SMSTSLogPath=C:\Windows\CCM\Logs\SMSTSLog]LOG]!><time="15:37:03.908+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[Expand a string: osdpreparesmsclient.exe]LOG]!><time="15:37:03.908+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:782"> <![LOG[Expand a string: ]LOG]!><time="15:37:03.908+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:782"> <![LOG[start executing the command line: osdpreparesmsclient.exe]LOG]!><time="15:37:03.908+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="instruction.cxx:2930"> <![LOG[!--------------------------------------------------------------------------------------------!]LOG]!><time="15:37:03.908+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="instruction.cxx:2959"> <![LOG[Expand a string: FullOS]LOG]!><time="15:37:03.908+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:782"> <![LOG[Executing command line: osdpreparesmsclient.exe]LOG]!><time="15:37:03.908+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="commandline.cpp:827"> <![LOG[Checks succeeded. Client meets capture requirements]LOG]!><time="15:37:04.048+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:715"> <![LOG[set TSEnv:SMSClientVersion=5.00.7804.1000 ok]LOG]!><time="15:37:04.064+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:1133"> <![LOG[successfully enabled provisioning mode.]LOG]!><time="15:37:05.686+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:1273"> <![LOG[Waiting for CcmExec service to be fully operational]LOG]!><time="15:37:05.686+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="utils.cpp:4305"> <![LOG[CcmExec service is up and fully operational]LOG]!><time="15:37:45.482+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="utils.cpp:4354"> <![LOG[Cache contents deleted successfully]LOG]!><time="15:37:45.653+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:112"> <![LOG[stopped the service 'ccmexec' successfully]LOG]!><time="15:37:58.555+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="servicecontrol.cpp:267"> <![LOG[successfully stopped the client agent service.]LOG]!><time="15:37:58.555+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:1169"> <![LOG[unAssigning the SMSClient succeeded]LOG]!><time="15:37:58.601+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:786"> <![LOG[Removing SitePolicy succeeded.]LOG]!><time="15:37:59.943+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:859"> <![LOG[Deleted 2 SMS certificates]LOG]!><time="15:37:59.943+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:1017"> <![LOG[Deleting Client properties from file C:\Windows\SMSCFG.INI succeeded.]LOG]!><time="15:37:59.943+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:922"> <![LOG[Reseting the Trusted Root Key successful]LOG]!><time="15:37:59.959+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:1088"> <![LOG[Deleting instance of 'CCM_Client' successful]LOG]!><time="15:37:59.959+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:170"> <![LOG[successfully reset Registration status flag to "not registered"]LOG]!><time="15:37:59.974+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:309"> <![LOG[successfully disabled provisioning mode.]LOG]!><time="15:37:59.974+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:1273"> <![LOG[start to cleanup TS policy]LOG]!><time="15:37:59.974+300" date="08-16-2013" component="PrepareSMSClient" context="" type="0" thread="3908" file="utils.cpp:3056"> <![LOG[End TS policy cleanup]LOG]!><time="15:38:00.037+300" date="08-16-2013" component="PrepareSMSClient" context="" type="0" thread="3908" file="utils.cpp:3104"> <![LOG[setting startup type for 'smstsmgr' service to manual..]LOG]!><time="15:38:00.037+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:949"> <![LOG['smstsmgr' service is configured to be manual]LOG]!><time="15:38:00.037+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:956"> <![LOG[sMS Client has been successfully prepared for OS capture]LOG]!><time="15:38:00.052+300" date="08-16-2013" component="PrepareSMSClient" context="" type="1" thread="3908" file="preparesmsclient.cpp:466"> <![LOG[Process completed with exit code 0]LOG]!><time="15:38:00.068+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="commandline.cpp:1123"> <![LOG[!--------------------------------------------------------------------------------------------!]LOG]!><time="15:38:00.068+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="instruction.cxx:3012"> <![LOG[successfully completed the action (Prepare Configuration Manager Client) with the exit win32 code 0]LOG]!><time="15:38:00.068+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="instruction.cxx:3038"> <![LOG[Do not send status message in full media case]LOG]!><time="15:38:00.068+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="utils.cpp:5182"> <![LOG[set a global environment variable _SMSTSLastActionRetCode=0]LOG]!><time="15:38:00.068+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a global environment variable _SMSTSLastActionSucceeded=true]LOG]!><time="15:38:00.068+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[Clear local default environment]LOG]!><time="15:38:00.068+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:807"> <![LOG[updated security on object C:\_SMSTaskSequence.]LOG]!><time="15:38:00.099+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="utils.cpp:1121"> <![LOG[set a global environment variable _SMSTSNextInstructionPointer=2]LOG]!><time="15:38:00.099+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a TS execution environment variable _SMSTSNextInstructionPointer=2]LOG]!><time="15:38:00.099+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:386"> <![LOG[set a global environment variable _SMSTSInstructionStackString=0]LOG]!><time="15:38:00.099+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a TS execution environment variable _SMSTSInstructionStackString=0]LOG]!><time="15:38:00.099+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:414"> <![LOG[save the current environment block]LOG]!><time="15:38:00.099+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:833"> <![LOG[start executing an instruction. Instruction name: Prepare Operating System. Instruction pointer: 2]LOG]!><time="15:38:00.130+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="engine.cxx:117"> <![LOG[set a global environment variable _SMSTSCurrentActionName=Prepare Operating System]LOG]!><time="15:38:00.130+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a global environment variable _SMSTSNextInstructionPointer=2]LOG]!><time="15:38:00.130+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a local default variable OSDBuildStorageDriverList]LOG]!><time="15:38:00.146+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:700"> <![LOG[set a local default variable OSDKeepActivation]LOG]!><time="15:38:00.146+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:700"> <![LOG[set a global environment variable _SMSTSLogPath=C:\Windows\CCM\Logs\SMSTSLog]LOG]!><time="15:38:00.146+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[Expand a string: osdprepareos.exe /activate:%OSDKeepActivation% /bmsd:%OSDBuildStorageDriverList%]LOG]!><time="15:38:00.146+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:782"> <![LOG[Expand a string: ]LOG]!><time="15:38:00.146+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:782"> <![LOG[start executing the command line: osdprepareos.exe /activate:%OSDKeepActivation% /bmsd:%OSDBuildStorageDriverList%]LOG]!><time="15:38:00.146+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="instruction.cxx:2930"> <![LOG[!--------------------------------------------------------------------------------------------!]LOG]!><time="15:38:00.146+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="instruction.cxx:2959"> <![LOG[Expand a string: FullOS]LOG]!><time="15:38:00.146+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:782"> <![LOG[Executing command line: osdprepareos.exe /activate:%OSDKeepActivation% /bmsd:%OSDBuildStorageDriverList%]LOG]!><time="15:38:00.146+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="commandline.cpp:827"> <![LOG[=======================[ OSDPrepareOS.exe ] =======================]LOG]!><time="15:38:00.286+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="main.cpp:211"> <![LOG[Local machine is not a domain controller.]LOG]!><time="15:38:00.317+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="deployutil.cpp:569"> <![LOG[system partition is NTFS]LOG]!><time="15:38:00.317+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="deployutil.cpp:494"> <![LOG[Verified deploy tools are present.]LOG]!><time="15:38:00.317+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="deployutil.cpp:415"> <![LOG[Local machine is not part of a domain]LOG]!><time="15:38:00.317+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="deployutil.cpp:534"> <![LOG[Emptying Recycle bin failed, hr=8000ffff]LOG]!><time="15:38:00.364+300" date="08-16-2013" component="PrepareOS" context="" type="2" thread="8844" file="prepareos.cpp:264"> <![LOG[Administrator account name = 'Administrator']LOG]!><time="15:38:00.364+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="prepareos.cpp:642"> <![LOG[ResetPassword operation successful]LOG]!><time="15:38:00.380+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="prepareos.cpp:789"> <![LOG[staging boot image HOK00008]LOG]!><time="15:38:00.380+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="bootimage.cpp:716"> <![LOG[Failed to open namespace 'root\CIMv2\Security\MicrosoftVolumeEncryption' (0x8004100E)]LOG]!><time="15:38:00.489+300" date="08-16-2013" component="PrepareOS" context="" type="3" thread="8844" file="encryptablevolume.cpp:407"> <![LOG[Failed to open namespace 'root\CIMv2\Security\MicrosoftVolumeEncryption' (0x8004100E)]LOG]!><time="15:38:00.489+300" date="08-16-2013" component="PrepareOS" context="" type="3" thread="8844" file="encryptablevolume.cpp:407"> <![LOG[ResolveSource flags: 0x00000000]LOG]!><time="15:38:00.489+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="resolvesource.cpp:3240"> <![LOG[sMSTSPersistContent: . The content for package HOK00008 will be persisted]LOG]!><time="15:38:00.489+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="resolvesource.cpp:3249"> <![LOG[Found Fullmedia content in drive D:\.]LOG]!><time="15:38:00.879+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="resolvesource.cpp:821"> <![LOG[Found boot image D:\SMS\PKG\HOK00008\boot.HOK00008.wim]LOG]!><time="15:38:01.019+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="bootimage.cpp:1114"> <![LOG[Copying boot image locally...]LOG]!><time="15:38:01.019+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="bootimage.cpp:744"> <![LOG[unable to copy boot image from 'D:\SMS\PKG\HOK00008\boot.HOK00008.wim' to 'C:\_SMSTaskSequence\WinPE\sources\boot.wim' locally. Data error (cyclic redundancy check). (Error: 80070017; Source: Windows)]LOG]!><time="15:38:04.451+300" date="08-16-2013" component="PrepareOS" context="" type="3" thread="8844" file="bootimage.cpp:769"> <![LOG[The user tries to release a source directory D:\SMS\PKG\HOK00008 that is either already released or we have not connected to it]LOG]!><time="15:38:04.451+300" date="08-16-2013" component="PrepareOS" context="" type="2" thread="8844" file="resolvesource.cpp:3641"> <![LOG[Failed to pre-stage WINPE image, hr=0x80070017]LOG]!><time="15:38:04.451+300" date="08-16-2013" component="PrepareOS" context="" type="3" thread="8844" file="prepareos.cpp:917"> <![LOG[unable to sysprep the machine, hr=80070017]LOG]!><time="15:38:04.451+300" date="08-16-2013" component="PrepareOS" context="" type="3" thread="8844" file="prepareos.cpp:1389"> <![LOG[sysprep'ing the machine failed, hr=80070017]LOG]!><time="15:38:04.451+300" date="08-16-2013" component="PrepareOS" context="" type="3" thread="8844" file="main.cpp:270"> <![LOG[Exiting with error code 23]LOG]!><time="15:38:04.451+300" date="08-16-2013" component="PrepareOS" context="" type="1" thread="8844" file="main.cpp:293"> <![LOG[Process completed with exit code 23]LOG]!><time="15:38:04.467+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="commandline.cpp:1123"> <![LOG[!--------------------------------------------------------------------------------------------!]LOG]!><time="15:38:04.467+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="instruction.cxx:3012"> <![LOG[Failed to run the action: Prepare Operating System. Data error (cyclic redundancy check). (Error: 00000017; Source: Windows)]LOG]!><time="15:38:04.467+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="instruction.cxx:3103"> <![LOG[Do not send status message in full media case]LOG]!><time="15:38:04.467+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="utils.cpp:5182"> <![LOG[set a global environment variable _SMSTSLastActionRetCode=23]LOG]!><time="15:38:04.467+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[set a global environment variable _SMSTSLastActionSucceeded=false]LOG]!><time="15:38:04.467+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:668"> <![LOG[Clear local default environment]LOG]!><time="15:38:04.483+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="executionenv.cxx:807"> <![LOG[Let the parent group (Capture the Reference Machine) decides whether to continue execution]LOG]!><time="15:38:04.483+300" date="08-16-2013" component="TSManager" context="" type="0" thread="4432" file="instruction.cxx:3212"> <![LOG[The execution of the group (Capture the Reference Machine) has failed and the execution has been aborted. An action failed. Operation aborted (Error: 80004004; Source: Windows)]LOG]!><time="15:38:04.483+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="instruction.cxx:2425"> <![LOG[Failed to run the last action: Prepare Operating System. Execution of task sequence failed. Data error (cyclic redundancy check). (Error: 00000017; Source: Windows)]LOG]!><time="15:38:04.483+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="engine.cxx:214"> <![LOG[Do not send status message in full media case]LOG]!><time="15:38:04.483+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="utils.cpp:5182"> <![LOG[Task Sequence Engine failed! Code: enExecutionFail]LOG]!><time="15:44:11.660+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="tsmanager.cpp:866"> <![LOG[****************************************************************************]LOG]!><time="15:44:11.660+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="tsmanager.cpp:889"> <![LOG[Task sequence execution failed with error code 80004005]LOG]!><time="15:44:11.660+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="tsmanager.cpp:890"> <![LOG[Cleaning Up.]LOG]!><time="15:44:11.660+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="tsmanager.cpp:637"> <![LOG[Removing Authenticator]LOG]!><time="15:44:11.660+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="tsmanager.cpp:648"> <![LOG[Cleaning up task sequence folder]LOG]!><time="15:44:11.660+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="utils.cpp:1746"> <![LOG[unable to delete file C:\_SMSTaskSequence\sms\bin\x64\CcmCore.dll (0x80070005). Continuing.]LOG]!><time="15:44:11.723+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="ccmfile.cpp:1056"> <![LOG[unable to delete file C:\_SMSTaskSequence\sms\bin\x64\CcmUtilLib.dll (0x80070005). Continuing.]LOG]!><time="15:44:11.723+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="ccmfile.cpp:1056"> <![LOG[unable to delete file C:\_SMSTaskSequence\sms\bin\x64\TsCore.dll (0x80070005). Continuing.]LOG]!><time="15:44:11.754+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="ccmfile.cpp:1056"> <![LOG[unable to delete file C:\_SMSTaskSequence\sms\bin\x64\TsManager.exe (0x80070005). Continuing.]LOG]!><time="15:44:11.754+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="ccmfile.cpp:1056"> <![LOG[unable to delete file C:\_SMSTaskSequence\sms\bin\x64\TsMessaging.dll (0x80070005). Continuing.]LOG]!><time="15:44:11.754+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="ccmfile.cpp:1056"> <![LOG[unable to delete directory C:\_SMSTaskSequence\sms\bin\x64 (0x80070091). Continuing.]LOG]!><time="15:44:11.754+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="ccmfile.cpp:1028"> <![LOG[unable to delete directory C:\_SMSTaskSequence\sms\bin (0x80070091). Continuing.]LOG]!><time="15:44:11.754+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="ccmfile.cpp:1028"> <![LOG[unable to delete directory C:\_SMSTaskSequence\sms (0x80070091). Continuing.]LOG]!><time="15:44:11.754+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="ccmfile.cpp:1028"> <![LOG[unable to delete file C:\_SMSTaskSequence\TSEnv.dat (0x80070005). Continuing.]LOG]!><time="15:44:11.754+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="ccmfile.cpp:1056"> <![LOG[Failed to delete directory 'C:\_SMSTaskSequence']LOG]!><time="15:44:11.754+300" date="08-16-2013" component="TSManager" context="" type="2" thread="4432" file="ccmfile.cpp:1218"> <![LOG[DeleteFile( failed for C:\_SMSTaskSequence\sms\bin\x64\CcmCore.dll]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:6225"> <![LOG[RemoveFile() failed for C:\_SMSTaskSequence\sms\bin\x64\CcmCore.dll. 0x80070005.]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:6232"> <![LOG[DeleteFile( failed for C:\_SMSTaskSequence\sms\bin\x64\CcmUtilLib.dll]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:6225"> <![LOG[RemoveFile() failed for C:\_SMSTaskSequence\sms\bin\x64\CcmUtilLib.dll. 0x80070005.]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:6232"> <![LOG[DeleteFile( failed for C:\_SMSTaskSequence\sms\bin\x64\TsCore.dll]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:6225"> <![LOG[RemoveFile() failed for C:\_SMSTaskSequence\sms\bin\x64\TsCore.dll. 0x80070005.]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:6232"> <![LOG[DeleteFile( failed for C:\_SMSTaskSequence\sms\bin\x64\TsManager.exe]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:6225"> <![LOG[RemoveFile() failed for C:\_SMSTaskSequence\sms\bin\x64\TsManager.exe. 0x80070005.]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:6232"> <![LOG[DeleteFile( failed for C:\_SMSTaskSequence\sms\bin\x64\TsMessaging.dll]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:6225"> <![LOG[RemoveFile() failed for C:\_SMSTaskSequence\sms\bin\x64\TsMessaging.dll. 0x80070005.]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:6232"> <![LOG[RemoveDirectoryW failed (0x80070091) for C:\_SMSTaskSequence\sms\bin\x64]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="2" thread="4432" file="utils.cpp:6316"> <![LOG[RemoveDirectoryW failed (0x80070091) for C:\_SMSTaskSequence\sms\bin]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="2" thread="4432" file="utils.cpp:6316"> <![LOG[RemoveDirectoryW failed (0x80070091) for C:\_SMSTaskSequence\sms]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="2" thread="4432" file="utils.cpp:6316"> <![LOG[setNamedSecurityInfo() failed.]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:6091"> <![LOG[setObjectOwner() failed. 0x80070005.]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:6103"> <![LOG[RemoveFile() failed for C:\_SMSTaskSequence\TSEnv.dat. 0x80070005.]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:6232"> <![LOG[RemoveDirectoryW failed (0x80070091) for C:\_SMSTaskSequence]LOG]!><time="15:44:11.770+300" date="08-16-2013" component="TSManager" context="" type="2" thread="4432" file="utils.cpp:6316"> <![LOG[Deleting volume ID file C:\_SMSTSVolumeID.7159644d-f741-45d5-ab29-0ad8aa4771ca ...]LOG]!><time="15:44:11.785+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="resolvesource.cpp:519"> <![LOG[successfully unregistered Task Sequencing Environment COM Interface.]LOG]!><time="15:44:11.785+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="environmentlib.cpp:886"> <![LOG[Missing TS Progress UI executable C:\_SMSTaskSequence\sms\bin\x64\TsProgressUI.exe.]LOG]!><time="15:44:11.785+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="utils.cpp:2213"> <![LOG[RegQueryValueExW failed for Software\Microsoft\SMS\Task Sequence, SMSTSEndProgram]LOG]!><time="15:44:11.785+300" date="08-16-2013" component="TSManager" context="" type="2" thread="4432" file="utils.cpp:261"> <![LOG[GetTsRegValue() failed. 0x80070002.]LOG]!><time="15:44:11.785+300" date="08-16-2013" component="TSManager" context="" type="2" thread="4432" file="utils.cpp:279"> <![LOG[End program: ]LOG]!><time="15:44:11.785+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="tsmanager.cpp:463"> <![LOG[Error executing Task Sequence Manager service. Code 0x80004005]LOG]!><time="15:44:11.785+300" date="08-16-2013" component="TSManager" context="" type="3" thread="4432" file="tsmanager.cpp:468"> <![LOG[sending error status message]LOG]!><time="15:44:11.785+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="tsmanager.cpp:471"> <![LOG[Do not send status message in full media case]LOG]!><time="15:44:11.785+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="utils.cpp:5182"> <![LOG[successfully finalized logs to SMS client log directory from C:\Windows\CCM\Logs]LOG]!><time="15:44:11.785+300" date="08-16-2013" component="TSManager" context="" type="1" thread="4432" file="tslogging.cpp:1542"> Quote Share this post Link to post Share on other sites More sharing options...
Peter33 Posted August 17, 2013 Report post Posted August 17, 2013 <![LOG[unable to copy boot image from 'D:\SMS\PKG\HOK00008\boot.HOK00008.wim' to 'C:\_SMSTaskSequence\WinPE\sources\boot.wim' locally. Data error (cyclic redundancy check). You might have some faulty boot media there. Quote Share this post Link to post Share on other sites More sharing options...
