I’m trying to deploy Vista images on our network here – I want it so that when the image is done being applied to a machine, the only account on there is the administrator with a password that was set in the Autounattend.xml file. I really cannot seem to get this working.
Since I don’t want any pointless accounts setup in the image (all the accounts will be setup manually after the computer is started), I set the SkipUserOOBE to true. I am under the belief that by doing this, I skip the welcome screen setup windows stuff (that asks to make user account and whatnot) – because I don’t want to setup any user accounts. I just want the administrator account pre-setup there with a password I give.
In the oobeSystem phase, I have the AdministratorPassword field in Microsoft-Windows-Shell-Setup_nuetral | User Accounts set to the password I want. I read through some help articles that suggested that simply by doing that, the administrator account is enabled with that password. This doesn’t seem to be working though. I also am being brought to the welcome screen as well… Any ideas? I attached the XML file that I’ve been using. Thank you so much!
P.S. – You’ll notice that I have info for a test account in there – I was just testing things. Once I’m in audit mode and I want to package it for the image, can I just do it from the sysprep GUI by chooing OOBE, Generalize, and shutdown? Or do I have to go it from the command prompt and specify the unattend:Autounattend.xml? Thanks again
Autounattend.xmlFetching info...
