Ocelaris Posted August 27, 2013 Report post Posted August 27, 2013 So my main site is in Massachusetts (USA), and we opened an office in Seoul, Korea. I'm getting all sorts of distribution point errors, so I figured it was a problem with the installation and uninstalled/reinstalled and now I'm in worse shape than when I started. We have 10 sites and all are working generally pretty good except this one. Other remote sites in Asia (Tokyo, Hong Kong, Shanghai) seem to be working fine. Latency from Tokyo to Massachusetts is 185ms Latency from Seoul to Massachussetts is 218ms WMI tests using WBEMTEST fail to connect from Massachussets to Seoul about half the time. They work from Tokyo to Seoul every time. Are there any settings to accomodate higher latency connections? Should I be putting a management point in Asia? The primary site server is in MA, so I'm not sure a second MP in Asia would even be responsible for pushing the DP installation and packages... I can set a Pull site in Asia, but at this point I can't even get the DP reinstalled. Thoughts? Quote Share this post Link to post Share on other sites More sharing options...
