HEHS_Matt Posted August 29, 2013 Report post Posted August 29, 2013 Hi folks, I'm having a huge amount of trouble with SCCM since I upgraded my system to 2012 SP1 and CU2. Since I installed these two updates, I can no longer successfully install any applications during a task sequence. It would also appear that I get the same errors when attempting to deploy software to completed machines. I have tried re-creating the task sequence from scratch, but the same errors occur. I have tried creating a brand new application and putting that in the task sequence, but the same errors occur. The SCCM admin console shows that the site has green lights across the board for site status and component status. The smsts.log file gives me the following errors for each application in turn: --- Execution status received: 16 (Application failed to evaluate ) Installation failed Install applicaiton action failed: '[application name]'. Error Code 0x80004005 --- Full logs attached. Similarly, the deployment status for applications in the Admin console shows errors on deployments as: Evaluation failed [application name] Error 0x80041013 Provider load failure Any help greatly appreciated - I've been staring at this problem for three days straight without getting any closer to understanding what's going on... MANY thanks in advance, -Matt MP_logs.zipFetching info... Quote Share this post Link to post Share on other sites More sharing options...
HEHS_Matt Posted August 29, 2013 Report post Posted August 29, 2013 UPDATE: Actually, it would appear that software *will* deploy to completed workstations, although it would appear to be a bit hit and miss at the moment... Still no joy on task sequences though. Quote Share this post Link to post Share on other sites More sharing options...
cliffjb Posted September 18, 2013 Report post Posted September 18, 2013 Hello, I am having the exact same issue. Did you figure this out? Quote Share this post Link to post Share on other sites More sharing options...
HEHS_Matt Posted September 23, 2013 Report post Posted September 23, 2013 On 9/18/2013 at 11:39 PM, cliffjb said: Hello, I am having the exact same issue. Did you figure this out? Nope. After much tail-chasing, I am today starting the process of trashing my SCCM servers and building them again from scratch... Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted September 24, 2013 Report post Posted September 24, 2013 have you tried removing and recreating the deployments ? Quote Share this post Link to post Share on other sites More sharing options...
