crizlok87 Posted September 24, 2013 Report post Posted September 24, 2013 Hi all, I've got a problem with my remote control in SCCM 2012 console. If I click on a Device Start --> Remote Control, it tries to start a RC-Session using the hostname. But the hostname cannot be resolved and it is not possible to add all the hostnames into the hostfile. Is it possible to tell the sccm-console to use the full qualified domain name, like hostname.domain.com? Because when I set up the connection manually using CmRcViewer.exe it works with hostname, IP and FQDN. I'd be glad about any kind of ideas or solutions :-) Greetings, Chris Quote Share this post Link to post Share on other sites More sharing options...
bra1nded Posted September 26, 2013 Report post Posted September 26, 2013 I am also interested to know if there is a way for SCCM to use FQDN. Our environment has many child domains. We have to add each domain to the "Append these DNS suffixes (in order)" section of TCP/IP settings of your network adapter. I think (but haven't been able to find documentation) that there is a character limit to this list. We have to frequently change the domains in our list so I keep the most common ones and change the odd ones when needed. Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\services\Tcpip\Parameters] "SearchList"="CommonDomain.org,YourDomain.org,MyDomain.org,OddDomain.org" Quote Share this post Link to post Share on other sites More sharing options...
bcunjak Posted October 4, 2013 Report post Posted October 4, 2013 you can launch the Remote Control Viewer from start menu and then choose option from pull down menu to Connect using once of the following; NetBIOS, FQDN, IP address. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted October 4, 2013 Report post Posted October 4, 2013 Quote But the hostname cannot be resolved and it is not possible to add all the hostnames into the hostfile. can you explain why it cannot be resolved, and why you cannot add the hostnames into a hostfile ? Quote Share this post Link to post Share on other sites More sharing options...
crizlok87 Posted October 7, 2013 Report post Posted October 7, 2013 On 10/4/2013 at 6:09 AM, bcunjak said: you can launch the Remote Control Viewer from start menu and then choose option from pull down menu to Connect using once of the following; NetBIOS, FQDN, IP address. Yes, this feature I already know, thanks anyway :-) Because of this feature, I thought, that it must be possible to use RC using the SCCM-console by right-click on the client. This would be more comfortable than typing in every single client. On 10/4/2013 at 8:52 AM, anyweb said: can you explain why it cannot be resolved, and why you cannot add the hostnames into a hostfile ? It is because of our internal infrastructure and policies. Quote Share this post Link to post Share on other sites More sharing options...
filmont79 Posted January 8, 2015 Report post Posted January 8, 2015 Sorry to bring up an old post, but was there ever any resolution to this issue? Quote Share this post Link to post Share on other sites More sharing options...
