psmiddleton
Build and capture
Hi
My SCCM server is on a V-Lan with no DHCP, so i am having trouble getting my build and capture TS to work on a VM i have created. i can't PXE boot as no ip is given to the VM, i created boot media and gave the VM a static ip in PE, but the TS fails, i think it is because the VM can't connect back to SCCM when it boots into Win7 to do the capture.
Any Ideas
Check the boudarys, because the IP you give the machine needs to be in the SCCM boudary (one of them atleast). Did you check that? can you even start the TS? i woudl recommend doing the process in MDT instead if you have that option :)
http://www.deploymentresearch.com/Research/tabid/62/EntryId/70/Going-Production-Deploy-Windows-8-using-MDT-2012-Update-1.aspx
