adv_marhal
Problems when ccmsetup verifies installation
Hi!
When the SCCM client is installing during the task it seems ok, but we alwasy get a non functional sccm client (the service is disabled).
Looking through then ccmsetup.log I found that it looks ok until the installation of the client is to be verified.
It ends up with this entries in the ccmsetup log
MSI: Åtgärd 14:02:14: InstallValidate. Bekräftar installation ccmsetup 2013-09-24 14:02:14 2520 (0x09D8)
File C:\WINDOWS\ccmsetup\{59A0EA77-D28C-4286-83A6-04BB57B9CDD6}\client.msi installation failed. Error text: ExitCode: 1603
Action:
ErrorMessages:
Next retry in 1 minute(s)... ccmsetup 2013-09-24 14:02:16 2520 (0x09D8)
If I check the Application log I have this entry at the exact same time as the verification fails:
Msi Installer Product: Configuration Manager Client - - The disk is full: Out of diskspace - - Volume D:...
I have tried with setting the CCMINSTALLDIR to c:\windows\ccm with no change in the result.
This fails every time, and if I reinstall the client maually it works fine.
Please help!
/BR
Martin
Just to clearify, my c: volume is the only disk volume in the machine.
The thing that I think is a bit strange is that when the verification runs and fails the application log show entries sugesting that the Config mgr client is trying to verify it's installation on the d: volume.
If thats right (that it tries to verify the install on D: and I can't see why it shouldn't be right) why is it doing that and how to change this behavior.
