KeithDib Posted September 25, 2013 Report post Posted September 25, 2013 At present I have two driver packages, one for XP the other for Windows 7 I want to change this to one for each make or model [not decided yet]. I know how to do this part with WMI etc what I cant do is get the existing drivers to show in the new driver packages. The drivers have already been imported as the message says but I thought these could be is more than one driver package? They are in the Windows 7 package for instance but dont seem to want to also show in the HP driver package is this normal? cheers Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted September 25, 2013 Report post Posted September 25, 2013 A driver can be part of multiple packages. When the driver is already imported, just right-click it in the console and add it to a package. A query to use in this situation, to apply the driver package to the correct device, is Select * From Win32_ComputerSystem Where Model Like '%Model%' Quote Share this post Link to post Share on other sites More sharing options...
KeithDib Posted September 26, 2013 Report post Posted September 26, 2013 A driver can be part of multiple packages. When the driver is already imported, just right-click it in the console and add it to a package. A query to use in this situation, to apply the driver package to the correct device, is Select * From Win32_ComputerSystem Where Model Like '%Model%' SO, I cannot re-import the drivers that are already there, but only select add to driver package? To right click in them all would take a while and I would need to know exactly what drivers for each machine Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted September 26, 2013 Report post Posted September 26, 2013 Well.. there is a hotfix to address the "issue" of importing duplicate drivers, see: http://support.microsoft.com/kb/2213600 Quote Share this post Link to post Share on other sites More sharing options...
