Morpheus
Run application from distribution point
I'd like to run some application direct from the distribution point. But every time it dowloads the content first to the client. Even when I deinstall the application.
The connection between client and server is definitely fast enough!
Or do I've to deploy everthing via a Batch which will start the applications via the Network? That can't be the solution!
  On 9/25/2013 at 1:29 PM, Bendes said:
SCCM 2012 does not allow this feature with "Application" deployment. You can only accomplish this with a "Package" and the option "Copy the content in this package to a package share on DP" on "Data Access" tab.
oaah, that's bad. Download 1GB to just install the software. That's very efficient.
