Brian.Hampson
SCCM 2012 - Minimum system requirements for PXE support on DP?
I'm trying to determine the minimum requirements for a DP in 2012 which I'd like to PXE enable.
What OS? What Bitness? I THOUGHT I had read that 64 bit was required, but seem to find contradictory information. I don't want to spend my days banging my head against a brick wall if something isn't possible.
More specifically I am looking to PXE enable the following two:
1) 2003R2 SP2 x86
2) 2008 Std SP1
Any specific advice as to how to make it WORK would be appreciated if they _ARE_ supported.
Thanks.
