edie209 Posted October 8, 2013 Report post Posted October 8, 2013 Our images were installing great and our task sequences had Office 2010 and google chrome installing. However since deploying SP1 the task sequence finishes after the "Setup Windows and Configuration" part of the task sequence even though I have steps after this i.e install updates, and install applications. I thought it might have been an issue with SP1 but I have since Upgraded to CU3 and still have the problem. I have attached a log file incase I am missing something really important smsts-20131008-174619.log Quote Share this post Link to post Share on other sites More sharing options...
edie209 Posted October 9, 2013 Report post Posted October 9, 2013 I think I have found the solution. If you right click on a Task Sequence you get the option to "Distribute Content" Well that seems to have done the trick both my applications have installed once a did this, maybe a schoolboy error in the that maybe you are meant to redistribute content after an upgrade??? Quote Share this post Link to post Share on other sites More sharing options...
