sccmnew Posted October 8, 2013 Report post Posted October 8, 2013 HI all i have been facing this prob from 1 week and trying to fix it but am unable to do that anyone please help me Am trying to setup remote DP on windows 2012 after installing DP it fails and display message distribution manager fail to connect DP check your firewall then after sometime it will show failed to connect DP Remotely check you firewall and network setting i have all rights on that machine(Remote DP) after 10-15 mins when i check it will shows this message Distribution Manager failed to process package "Configuration Manager Client Package" Possible cause: Distribution manager does not have access to either the package source directory or the distribution point. Solution: Verify that distribution manager can access the package source directory/distribution point. Possible cause: The package source directory contains files with long file names and the total length of the path exceeds the maximum length supported by the operating system. Solution: Reduce the number of folders defined for the package, shorten the filename, or consider bundling the files using a compression utility. Possible cause: There is not enough disk space available on the site server computer or the distribution point. Solution: Verify that there is enough free disk space available on the site server computer and on the distribution point. Possible cause: The package source directory contains files that might be in use by an active process. Solution: Close any processes that maybe using files in the source directory. If this failure persists, create an alternate copy of the source directory and update the package source to point to it. here is my log file distmgr.txt Quote Share this post Link to post Share on other sites More sharing options...
