mooks Posted October 9, 2013 Report post Posted October 9, 2013 Hi All, I have been trying to work this out for a week now. We have just setup SCCM 2012, and are starting to deploy new DPs Now the DPs that we are to use, also have other roles assigned to them. Mainly they are Lotus Notes Domino Servers I have successfully installed the DP roles to these servers, and the packages have transferred across all ok, but during our first deployment it seems we are getting these error messages in the contenttransfermanager logs. Successfully sent location services HTTP failure message. Error sending HEAD request. HTTP code 404, status 'Not Found' Persisted locations for CTM job {E80FD15A-F656-4E0E-9313-E5DF447F9443}: (LOCAL) http://xxxx.xxxx.com/SMS_DP_SMSPKG$/Content_b61b4a9f-27f2-49a3-8a28-2a254fd681ea.1 [CCMHTTP] ERROR: URL=http://xxxx.xxxx.com/SMS_DP_SMSPKG$/Content_b61b4a9f-27f2-49a3-8a28-2a254fd681ea.1, Port=80, Options=224, Code=0, Text=CCM_E_BAD_HTTP_STATUS_CODE I have tried the following I tried browsing to that link, and I get a 404 error. Looking locally using windows explorer I can see the files are indeed there. Could the issue be, that since Domino itself uses Port 80 for webmail, hence SCCM cant use that port, and therefore the client cannot download anything? Also, how would I get around this issue? Is it possible to change the ports that sccm uses for communication? Quote Share this post Link to post Share on other sites More sharing options...
