ahanso Posted October 9, 2013 Report post Posted October 9, 2013 Hi, I am having difficulties installing a package I made for Lync 2013. I can run everything just fine if I manually open a command prompt and perform the install, but when I push it to the clients and select "Install", software center sits there and spins at "Installing". I am confused because I have pushed packages before with no problem, however this is the first time I have tried in awhile. Something else I noticed that was strange is I have several updates sitting there at "Downloading (0% Complete)". Any suggestions on what could cause this? THANK YOU IN ADVANCE! Tony Quote Share this post Link to post Share on other sites More sharing options...
AmrelMahdy Posted October 9, 2013 Report post Posted October 9, 2013 Did the Client download the Lync Package in the SCCM cache folder ?, if yes , Can your run the Package manually on the same computer and Logged in user ? Quote Share this post Link to post Share on other sites More sharing options...
ahanso Posted October 9, 2013 Report post Posted October 9, 2013 Thank you for the reply. Yes it does download to the ccmcache folder and works fine if I kick it off manually. Logged in as the same user! I don't understand. Quote Share this post Link to post Share on other sites More sharing options...
Iroqouiz Posted October 10, 2013 Report post Posted October 10, 2013 Are your boundaries ok? Quote Share this post Link to post Share on other sites More sharing options...
AmrelMahdy Posted October 10, 2013 Report post Posted October 10, 2013 check execmgr.log file Quote Share this post Link to post Share on other sites More sharing options...
ahanso Posted October 10, 2013 Report post Posted October 10, 2013 On 10/10/2013 at 6:31 AM, Iroqouiz said: Are your boundaries ok? Would the package even download to my machine if the boundaries were not correct? Quote Share this post Link to post Share on other sites More sharing options...
Iroqouiz Posted October 10, 2013 Report post Posted October 10, 2013 On 10/10/2013 at 1:02 PM, ahanso said: Would the package even download to my machine if the boundaries were not correct? Guess not. Any alerts on the DP? Quote Share this post Link to post Share on other sites More sharing options...
