Auto-assign computername in OSD Deployment with VB Script
Hi everyone,
I am trying to deploy windows 7 computers in our company environment and they should get dynamic names.
This is how it should work:
- We have an Active Directory OU assigned to deployed workstations. I have 2 dummy computers in here just to test the setup, it looks like this atm.
- Next I have a script which reads the ou and generates the new computername
- I created a package with the script and distributed it to the DP
- Then i created a new task in the task sequence who performed a command line:
- when i am deploying I get the following error message:
Is there anyone that knows if this is possible to do, to start with. If my script is having errors in it, or what I am doing wrong? :)
Kind regards,
Thomas
I made it work, he is loading in my script in the task sequence, but i'm getting the next error:
Why go through the custom VBScript route? There is a good method built into MDT for naming machines and adding it to an OU structure. Create a customsettings.ini package from MDT, and use this naming convention. I imagine there is a walk through, we have had this in our environment for a long time and it works quite well.
