Jayshaw91 Posted October 29, 2013 Report post Posted October 29, 2013 We've got Primary and Secondary Sites. Clients in the Primary Site all show as active. A large number of clients show as inactive in the Secondary Sites. To troubleshoot, I followed this: http://be.enhansoft.com/post/2013/07/25/Troubleshooting-Inventory-Flow.aspx I checked that the client is talking to the MP in the SS. I see activity in the IIS log. The SS shows it is processing the record (checked the mp-hinv log) and it is putting it in the dataldr inbox, locally. Here is where I am confused. The MP (the only server in the SS) doesn't have a dataldr.log file. First question, should it have that file? For the record, I do see a dataldr.log on the Primary Server. I don't see the MIF being processed there. I don't even know if it should process it. My assumption is that the SS write the info the the database locally, but I am not 100% sure of that. Does file replication have anything to do with this or just the DDRs? Quote Share this post Link to post Share on other sites More sharing options...
Jayshaw91 Posted October 29, 2013 Report post Posted October 29, 2013 I should add that that Primary Site is SP1, and the Secondary Site where I checked the logs is also SP1. Client I checked has v.7804 of the agent installed. Quote Share this post Link to post Share on other sites More sharing options...
Jayshaw91 Posted October 31, 2013 Report post Posted October 31, 2013 This one has been solved. As I asked - and now have answered - file replication was the cause of the problem. Replication from Secondary Sites to the Primary Site was disabled due to bandwidth issues. We've re-enabled replication for all priorities (system info is LOW priority!) and set it to 5%/hr utilization. Keep that in mind, folks: do *not* turn off your file replication *to* your Primary Site! Throttling? Sure, just don't turn it off entirely. Quote Share this post Link to post Share on other sites More sharing options...
