mohanad
What is the best way to Clear CCM Cache?
I am trying to find a best way to clear the ccm cash folder , i found some script to do that, but i want to share it with you,any idea?
Dim objFSO
Dim objFolder
Dim objSubFolder
Dim winsh
Dim winenv
'deletes folders with a date modified of 120 day or older
Const intDaysOld = 120
set winsh = CreateObject("WScript.Shell")
set winenv = winsh.Environment("Process")
windir = winenv("WINDIR")
Set objFSO = CreateObject("Scripting.FileSystemObject")
'looks for \system32\ccm\cache for 32bit
if objFSO.FolderExists (windir & "\system32\ccm\cache") Then
Set objFolder = objFSO.GetFolder(windir & "\system32\ccm\cache")
For Each objSubFolder In objFolder.SubFolders
If objSubFolder.DateLastModified < DateValue(Now() - intDaysOld) Then
objSubFolder.Delete True
End If
Next
Wscript.quit
End if
'looks for \sysWOW64\ccm\cache for 64bit
if objFSO.FolderExists (windir & "\sysWOW64\ccm\cache") Then
Set objFolder = objFSO.GetFolder(windir & "\sysWOW64\ccm\cache")
End If
Next
End if
Thanks in advance
