Special Ed Posted January 8, 2014 Report post Posted January 8, 2014 I'm running SCCM 2012 sp1 with MDT integration. I'm using a UDI from MDT to set some basic machine informatoin for imaging (select the OU in the domain, etc). I also have some optional apps that a tech can select from the UDI to install during the TS. All is working great with network based installations. However, I have a need for some installations using stand alone media. Is there a way to create stand alone media that will include those optional apps in the MDT UDI so that those apps can install during the TS? I don't think there is, but there are more brilliant minds than mine out there so I thought I would ask. In case you aren't sure what I'm talking about, check out Niall's instructions on setting up the 'install programs' step in the UDI designer here: http://www.windows-noob.com/forums/index.php?/topic/5250-using-sccm-2012-rc-in-a-lab-part-18-deploying-a-udi-client-task-sequence-with-mdt-2012-rc1-integrated-in-configuration-manager-2012/ I want a stand alone USB drive to be able to install the Mozilla and Winzip apps that are selected during deployment in his example. Ed Quote Share this post Link to post Share on other sites More sharing options...
