newadmsccm
Components Offline in SCCM 2012
Hi Guys,
I have checklist in Monitoring/System Status/Component Status and I have 4 components com Avaliability: OFFLINE.
But, I don't have any problem with my task Backup by example and my System Discovery Agent run too without problem.
So someone can help understand, why they are offline?
Thanks.
Maybe offline due to the fact these components are not running when you are looking at this.
When your backup is next due to run have a look then and it should be online.
OR
manually run a system dicovery and watch it change to an online state.
It's fine to be like this aslong as they change to an online state when the schedule kicks in!!
OR
Thanks Rocket Man, I will see if these components are change status when are run.
Well, I read some information about my doubt. and found this link where have more information:
http://www.informit.com/articles/article.aspx?p=1926197&seqNum=5
I believe my components are OK and I don't have any problem, but, I will see next days.
Thanks.
