Mattster
MDT - Multicast required on additional WDS Servers
Hi All,
I have deployed MDT throughout our business using WDS as the deployment mechanism through PXE, however have noted a problem today.
Scenario:
Server A running WDS, MDT and WAIK
Server B running WDS (I have since added MDT and WAIK without success) - Info to follow.
I wish to deploy using a multicast stream. Server A works, however Server B does not.
I have DFS-R replicating the deployment share and RemoteInstall\boot folder to 'Server B' but it appears multicast transmission is not enabled.
Can you advise how I can get this working.
As it stands site B using 'Server B' is broadcasting which is not acceptable.
I have followed the link here but does not appear to work although added the multicast feature on Server B.
Help appreciated!
Many thanks in advance.
