had an issue and work and lost some data so I went coming thru log files. turns out, this version passes /o to the command line to overwrite an old document store. I opened a ticket with Microsoft and they had to send it to the product group. (there is no program to modify the command line)
also, usmt.mig can no longer be opened using migwiz. migwiz will crash on a win8.1 machine, and tell you the file is corrupt on win7. you can however use the usmtutils.exe file to extract it..
i created a simple gui interface that passes all the command so my techs can just copy and paste the recovery data from the console. (usmtutils support unc paths)
usmtutils.exe /extract usmt.migpath extractdestination /decrypt /key:
hope this helps someone.
