sweety_devil
Task sequence with Wifi
dear all,
I wanted to deploy Windows 8.1 64bits on Surface pro 2 in using the wireless adapter.
I have sccm 2012R2.
I used the boot image x64 (WinPE 5) and I have installed dot3svc addin.
I have a command line to install my wifi profile which is netsh wlan ... but I receive an error message because the system can't find wlan !
Could you help me ?
Thank you.
Check out the link below (should work the same for Surface 2) , your best bet for imaging it will be to use the USB Ethernet adapter or make a stand-alone media on a flash drive.
http://download.microsoft.com/download/2/0/7/2073C22F-2F31-4F4A-8059-E54C91C564A9/Surface%20Pro%20-%20Enterprise%20Deployment%20Quick%20Start%20Guide.pdf
I have already created a task sequence with USB Ethernet adapter and it works well !
But I m trying to create a task sequence media with no network access on a usb key.
The problem is I need to add the computer to active directory in the WinPe phase and I wanted to do it in Wireless mode !
How can I do that?
Thank you.
