willquan22 Posted February 10, 2014 Report post Posted February 10, 2014 Hi, i am running into a major issue with my task sequence. i am trying to deploy a capture and OSD. when i make it required it does not automatically run. it used to in the past but all of sudden it stopped. so i would deploy the task sequence make it required and nothing happens. i would also manually run the machine policy. when i make it available and manually run the machine policy it shows up. has anyone encountered this issue? Quote Share this post Link to post Share on other sites More sharing options...
